oil filter - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 00fordsd, this thread has received 18 replies and been viewed 1722 times.
post #1 of 19 (permalink) Old 07-31-2009, 01:58 PM Thread Starter
oil filter
im going to be changing my oil in my 2000 7.3 this weekend and was wondering what filter everyone on here uses. brands where you get them that kind of stuff. stopping on my way home from work so some fast responses would be great. thanks guys and gals
00fordsd is offline
post #2 of 19 (permalink) Old 07-31-2009, 03:10 PM
4cstr's Avatar
Images: 35
Walmart carries the Motorcraft brand which is good. Some of the parts stores carry Purolators which are also good filters.
~Dave~
4cstr is offline
post #3 of 19 (permalink) Old 07-31-2009, 04:18 PM
dmd
dmd's Avatar
+1
Just do not use Fram!
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, Tony Wildman 6-pos chip, Custom 4-inch intake, 4-inch turbo-back exhaust, ATS housing, Adrenaline HPOP, BTS Trans, EBPV delete, ITP overboost eliminator, in-tank and pre-pump mod, Heater valve mod
dmd is offline
post #4 of 19 (permalink) Old 07-31-2009, 04:21 PM
4cstr's Avatar
Images: 35
Originally Posted by dmd View Post
+1
Bahh....
I've got a Fram on the truck now...and had one last oil change. Blackstone says filtration is fine without issues.
Trouble with Fram is that you pay for the name. Their filtration is no better...or worse...than Motorcrafts or Puro's...
The reason I am running them right now is that I caught Advance Auto selling Frams 2 for 5 bucks awhile ago...with no stipulation about more expensive filters in their ad or in the store. The high school dude behind the counter just rang 'em up at the 2 for 5 price. Bought all that they had
~Dave~
4cstr is offline
post #5 of 19 (permalink) Old 07-31-2009, 11:08 PM
balz out's Avatar
i use k&n can get it at autozone.... any oil filter that has a anti drain back valve is what you want...helps prevent dry starts....fram = the devil!!!
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #6 of 19 (permalink) Old 07-31-2009, 11:11 PM
Bunker Buster
I use Wix
97 F-350 Dually 5spd 4.10's Daily Driver/Tow Rig
Open air intake, open exhaust, TS 6pos chip, 1.0 ATS turbo housing, gauges
86 CUCV Blazer Rock Crawler 6.2 Diesel, 4spd, 208, locked One Tons, 5.13's, H1 12 Bolt double bead locks
05 Dodge 3/4T Cummins/6spd (Wifes)
Buster is offline
post #7 of 19 (permalink) Old 07-31-2009, 11:13 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
I use Amsoil EAO99.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #8 of 19 (permalink) Old 08-01-2009, 12:16 AM
4play's Avatar
motorcraft FL-1995. if the filter is upside down like these then you dont need to worry about the anti-drain back valve. stay away from the cheapos especially FRAM. If you believe in FRAM or the other cheapos just cut one open and take a look inside, you wont ever buy another FRAM if you did.
4play is offline
post #9 of 19 (permalink) Old 08-01-2009, 01:47 AM
4cstr's Avatar
Images: 35
I did...no cardboard...metal welded ends. I really looked no different that any of the others I have cut open.
Now..that said...I won't run one on any of my cars. I have seen the cardboard ends on those.
~Dave~
4cstr is offline
post #10 of 19 (permalink) Old 08-01-2009, 02:49 AM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
NAPA/Wix
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
Aeromotive inline fuel filter canister with new filter for stage 2 and 3 fuel systems maxxis_mudder Ford Parts 5 09-08-2009 01:04 AM
Aeromotive aluminum fuel filter canister w/new 10 micron fuel filter and -10 adapter maxxis_mudder Whats Been Sold 0 02-13-2009 01:05 AM
Oil filter cap and fuel filter cap size Redleg 2008-2010 6.4L Power Stroke 7 02-09-2009 06:40 AM
early 08 Torqshift filter to Job2 Filter BKB 2008-2010 6.4L Power Stroke 0 01-26-2009 08:41 PM
oil filter/fuel filter housing droolinforparts 2003-2007 6.0L Power Stroke 16 03-06-2008 05:31 PM
