wont start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by southtexasidi, this thread has received 4 replies and been viewed 1412 times.
post #1 of 5 (permalink) Old 07-31-2009, 04:15 PM Thread Starter
southtexasidi's Avatar
wont start
my dads 01 7.3 wont start.the other day we started it and it had a lope at idle.im lost and dont know what could be wrong.it has been a little hard to start latly and now it just wont.help me out guys
mine: 1986 F250 6.9 idi
dads: 2001 F250 platinum edition 7.3 powerstroke
also 1966 MACK B53.in the process of restoring.
american club # 31
singles club # 218
southtexasidi is offline
post #2 of 5 (permalink) Old 08-01-2009, 01:54 AM
SmokeCloud's Avatar
You throwing any codes?
Real Trucks Burn Diesel!
SmokeCloud is offline
post #3 of 5 (permalink) Old 08-02-2009, 04:25 AM
TDG Mafia Member # 37
01blkf250's Avatar
Without pulling codes I'm just guessing but it sounds like you have low ICP (injection control pressure) or you're not getting fuel. When was the last time the fuel filter was changed? You need somewhere around 500 psi of oil from the HPOP (high pressure oil pump) to fire the injectors. If it was loping and then not starting it sounds like low oil pressure to the injectors to me. Could possibly be a bad IPR (injection pressure regulator),that's what was wrong with mine about 3years ago. Gene
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
post #4 of 5 (permalink) Old 08-04-2009, 08:30 PM
SmokeCloud's Avatar
+1 to that.
post #5 of 5 (permalink) Old 08-08-2009, 05:01 PM
01blkf250's Avatar
Any word on what was wrong?
125 wont start sexytrkr ATV, UTV, Dirtbike Forum 5 04-03-2009 04:18 PM
Wont start..? HeffPsDiesel 1994-2003 7.3L Power Stroke 15 04-20-2008 07:33 AM
97 wont start Fireguy 5.9L Cummins 12 Valve (1994-1998.5) 5 10-25-2007 12:32 PM
wont start doob51 5.9L Cummins 12 Valve (1994-1998.5) 3 05-06-2007 02:05 PM
