2000 Needs Waterpump. Advice - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by acesneights1, this thread has received 11 replies and been viewed 1528 times.
post #1 of 12 (permalink) Old 08-02-2009, 04:41 PM Thread Starter
acesneights1's Avatar
My father's truck just spit the waterpump bigtime. Fan blade is damaged as well. If you guys could some quick pointers on replacement. Looking down from bird's eye view it actually looks pretty easy to do which is what worries me... . Here's my questions since I have not worked on a PS.
Where should I get the new one ? Advanced Auto has New for 150$
Where should I get the fan ? Ford ? Is there a better place ?
Oviously I should do both hoses and thermostat. Will generic Thermostat be ok or does it need to come from Ford ?
It almost looks like I can pull the WP without removing any accessories ??
I am a diesel Mechanic so I don't need step by step, just want to make sure there are no surprises I am not seeing. Also what Coolant goes in it ? I'll assume the truck is all stock. My Dad is crippled , My 76 yr old Mother uses the truck to plow the driveway. So it doesn't tow or get used hard or require IMHO any crazy upgrades. Just need to fix it.
Thanks.
1986 CUCV....M1008 6.2 NV4500 5 spd
Raptor 100 LP. Serp belt conversion. 5 inch redneck master exhaust. DB2831 IP. Dmax fan. Humvee waterpump.
1981 AM General M35A2c
Lee's Auto Ranch In Ellington CT SUCKS !!
acesneights1 is offline
post #2 of 12 (permalink) Old 08-02-2009, 04:59 PM
********* and Mafia #90
Bcarriveau's Avatar
I would get one with a good warranty.
How bad is the fan? ifs its bad i would deff replace it. if its a small dent dont worry.
Both hoses would be fine,
Thermostats are either good or bad so why replace .
Remove shroud and fan together.
If its the same size as a 95 its a 48MM for the fan nut. then we used the 54mm fan wrench to hold the pulley from moving(fits over the pully bolts)
Da Rules..Here
Windows 7 Takes the WIN!
Windows 8 might take that Win
http://www.bcarriveau.com/
Dear Tequila:
The TDG TOTQ
Bcarriveau is offline
post #3 of 12 (permalink) Old 08-02-2009, 05:38 PM Thread Starter
I was always taught do the thermostat when you do the WP. Fan is plastic and one of the blades has a crack so it's gotta be changed.
post #4 of 12 (permalink) Old 08-02-2009, 05:42 PM
Bcarriveau's Avatar
Right on, its cheap so what the heck
Sorry i cant help with a location for buying the fan. Im partial to ford parts if its not to much more then a off brand.
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #5 of 12 (permalink) Old 08-02-2009, 06:04 PM
check the ford and international dealers for the fan. Get an upper hose for a dual alternator set up. Makes it so you can change the belt without having to take of the hose. Your almost certain to have to get the adapter (can't think of name) the upper hose goes into it will almost certainly leak if you don't.
Pat 2000 F250
5"exhaust with 6" tip, mac intake, foil delete and zoodad :ford
silverf250 is offline
post #6 of 12 (permalink) Old 08-02-2009, 06:07 PM
Bcarriveau's Avatar
The neck that sits on top of the t-stat and hose goes to?
Da Rules..Here
Dear Tequila:
The TDG TOTQ
post #7 of 12 (permalink) Old 08-02-2009, 06:41 PM
Yes, It's very cheaply made everyone I know has had to replace it. after taking it off.
Pat 2000 F250
post #8 of 12 (permalink) Old 08-02-2009, 10:37 PM Thread Starter
OK so Advanced Auto WP should be OK. Go to ford for the fan.
post #9 of 12 (permalink) Old 08-03-2009, 12:04 AM
It better be. that's what I have. As far as the fan you can check any parts store but that might be something they don't carry. I'd still check with Ford some times their parts prices end up being cheaper. If you accidentally drop the temp sensor in the water pump definitely get it from Ford, it is cheaper.
Pat 2000 F250
post #10 of 12 (permalink) Old 08-17-2009, 12:48 AM Thread Starter
well here's the pump. A few miles more and the timing case cover would have been gone too. It was gouged up a little but think it will be ok.
ID:	21158   Click image for larger version
Replacing the waterpump on an LB7/LLY Duramax TheBac Chevy - Modification instructions, Product installs and Tech Articles 5 01-29-2012 09:41 PM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 11:08 PM
2000 Rpm? Andy King 1994-2003 7.3L Power Stroke 13 08-20-2007 10:00 AM
2000 PSD waterpump Messi 1994-2003 7.3L Power Stroke 15 05-12-2006 04:48 PM
2000 PSD waterpump Messi 1994-2003 7.3L Power Stroke 8 02-10-2006 01:32 PM
