Rusty oil pan syndrome...help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TowRig, this thread has received 3 replies and been viewed 1112 times.
post #1 of 4 (permalink) Old 08-02-2009, 09:36 PM Thread Starter
Send a message via AIM to TowRig
What do you do to solve this??? I heard you have to pull the whole engine to get this done is this correct? I need some information on this because I am afraid I need to change my oil pan in the very near future.
Please help guys,
Thanks
AJ
2000 F-250 PSD Extended Cab Short Bed
-AutoMeter Gauges;Pyro, Tranny, Boost, Rear Diff, Fuel Pres, Air Pres.
-MBRP Turbo back, muffler delete
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
Trail rig: 1990 Jeep Cherokee, 4.0 I6, NP231 w/ SYE, Clayton Off road Long arm Suspension with coil conversion in rear, Full width Dana 44 up front(ARB, Warn Hubs and US Alloys Chromoly Axle shafts), full width Dana 60 in rear with Spool. 4.88 Gears all around, 36 inch Interco Bias Irok's, and lots of trail damage. :
TowRig is offline
post #2 of 4 (permalink) Old 08-02-2009, 09:40 PM
4cstr's Avatar
Images: 35
I know of some guys who have sanded down the area to get to good metal...then undercoated the thing. It may only be a temporary band-aid though.
But yeah...if the oil pan rusts through and through...then yep...the motor has to come out to get replaced.
~Dave~
4cstr is offline
post #3 of 4 (permalink) Old 08-02-2009, 09:47 PM
Banned
A friend of mine just has this same issue. He cleaned and stripped the pan the best he could. Put on POR 15 rust stopper. Then used spray on bed-liner.
Trick is to make sure all the oil gets worked out of the cracks first. By using brake clean or electro-wash. If you dare a little heat to drive out the oil also helps. He also let his truck sit for a month with no oil in it to give it ample time to cure..
wastedwagesracing is offline
post #4 of 4 (permalink) Old 08-02-2009, 11:01 PM Thread Starter
Thanks Guys
-AFE Stage II
-ITP Oil HPX Line
-CCV Mod
-AIH Delete
TowRig is offline
Rusty and broken line off of exh manifold bigbear3 1994-2003 7.3L Power Stroke 6 02-05-2009 02:34 AM
Rusty Dodges Why JWC-PERFORMANCE 5.9L Cummins 12 Valve (1994-1998.5) 5 05-27-2007 04:31 PM
