Auxilarry idle Control - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by brendonv, this thread has received 4 replies and been viewed 1318 times.
post #1 of 5 (permalink) Old 08-03-2009, 01:48 AM Thread Starter
brendonv's Avatar
So I found a FORD AIC locally for a econoline van with the 7.3 .
Does anyone know if it'll plug into the harness on a superduty?
My guess would be that the van has the same harness as the superduty, but not really sure.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #2 of 5 (permalink) Old 08-03-2009, 03:49 AM
Yoslick's Avatar
I know it will fit my 96 so if that matches yours your good to go!
DCC(SW/MTS) USN-Ret 75-95
96 F-250 4x4 7.3 73k
3" DP
Gutless Kitty
DIY Air filter (NAPA 6637)
3 Gage Pod
14.6k Mod
Yoslick is offline
post #3 of 5 (permalink) Old 08-03-2009, 04:54 AM Thread Starter
brendonv's Avatar
Cool, thanks.
It has no screen, I'm wondering if the one with the screen is much better or not. From what I've read, the screen just shows the RPM's and voltage. I can live without though.
brendonv is offline
post #4 of 5 (permalink) Old 08-04-2009, 08:42 PM
dmd
dmd's Avatar
I believe there are several types (with and wo screen, with and wo PTO) and each has a different harness.... BUT I think they will plug in under the dash. You might want to run the part number by someone that can look it up and verify it will work with your year.
Mine has the screen and the PTO, nice to have the voltage. Digital
tac it nice too.
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, Tony Wildman 6-pos chip, Custom 4-inch intake, 4-inch turbo-back exhaust, ATS housing, Adrenaline HPOP, BTS Trans, EBPV delete, ITP overboost eliminator, in-tank and pre-pump mod, Heater valve mod
dmd is offline
post #5 of 5 (permalink) Old 08-07-2009, 10:40 PM Thread Starter
brendonv's Avatar
Soo, I ended up getting one on ebay, brand new in the box with everything for $90 shipped to my door. It should be here tommorrow or monday/tues. Where is the truck side plug in on the superduty? I'm thinking it's right there in front of me mounted on the bottom frame that holds the fuse door on. But that would be too easy!
brendonv is offline
Cant set idle with cruise control? jethrow 2003-2007 6.0L Power Stroke 20 02-15-2008 05:59 PM
Auxillary Idle Control CFRO 1994-2003 7.3L Power Stroke 11 10-23-2007 08:43 PM
Stationary idle control install with pics. PSDPlayer 2003-2007 6.0L Power Stroke 1 10-11-2005 11:04 AM
Operating Instructinos for the Auxillary Idle Control Module PSDPlayer 1994-2003 7.3L Power Stroke 0 09-26-2005 09:44 PM
Anyone running an AIC (Aux Idle Control) on your 6.0? imported_Arkapigdiesel 2003-2007 6.0L Power Stroke 29 08-26-2005 08:50 PM
