99 f-450 7.3D oil pan leak help! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Twin Star Farm, this thread has received 2 replies and been viewed 3796 times.
post #1 of 3 (permalink) Old 08-03-2009, 10:30 PM Thread Starter
i have a 1999 f-450 7.3d single cab with a flat bed i have a major oil pour at the point where the dipstick goes through the oil pan. i have tried to tighted the retaining nut but it will not tighten. what do i do??? thanks for your help
Twin Star Farm is offline
post #2 of 3 (permalink) Old 08-05-2009, 04:29 AM
international sells a kit to reseal the dipstick adaptor. as i recall, the kit contains a new nut, a paper gasket and some of the gray rtv like is used for the pan gasket itself. the kit does not contain one but you should try and get a new o-ring for where the dipstick goes into the adaptor itself. remove the dipstick from the adaptor and stick a 1/2" rifle brush in its place. remove the old nut and the rifle brush should hold the adaptor well enough so it won't fall into the oil pan. there is an o-ring on the inside of the pan that was used to seal the adaptor but you should remove that. then you put the gasket on the outside of the pan with some rtv and install the new nut. reinstall the dipstick with a new o-ring on that as well. don't quote me on those directions but i think it's pretty close to that. this was a few years back i did this on my truck put i think instructions came with the kit too. have absolutely no idea on any part numbers though.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #3 of 3 (permalink) Old 08-06-2009, 11:46 AM Thread Starter
sdan27, thanks for your input, but i had to have this truck back on the road asap. so i sent it to the closest ford dealership. everything that i read or heard the engine had to almost come out to get the oil pan off. that was something that i did not want to tackle. thanks for your advice!!!! Twin Stat Farm
Oil leak utlonghorns416 2003-2007 6.0L Power Stroke 3 11-05-2007 03:32 PM
7.3 oil leak a big one smokn03 1994-2003 7.3L Power Stroke 18 10-11-2007 01:33 AM
oil leak powerstroke03 2003-2007 6.0L Power Stroke 11 05-16-2007 03:08 AM
Oil Leak jktcummins 5.9L Cummins (1998.5-2002) 30 04-09-2007 12:07 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
