6.0 trans cooler install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kip, this thread has received 8 replies and been viewed 2108 times.
post #1 of 9 (permalink) Old 08-04-2009, 11:45 PM Thread Starter
Kip
In the passing lane
Kip's Avatar
ok I got a 6.0 trans cooler for 40 bucks. How hard is it to install? We else do I need to do the install?
2005 2500HD DIRTYMAX 6in lift, dual exhaust, afe airbox. Tuner soon to come
2001 PSD shortbed crewcab, ATS tranny edge juice w/attitude, Superchips programmer, Gauges, exhaust, 4inch lift w/35s, (SOLD)
Originally Posted by sledneck57
Your sweating like a queer holding a hot dog.lol.
Kip is offline
post #2 of 9 (permalink) Old 08-05-2009, 01:38 AM
beware the dark side
not to hard will bolt right into the same location as the cooler already on your truck. only need to modify the hoses into and out of the cooler and attach them to your trans lines. I just used rubber hose and some high pressure hose clamps.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #3 of 9 (permalink) Old 08-05-2009, 04:31 AM
4cstr's Avatar
Images: 35
You can't. But...being the nice guy I am...I'll take it off your hands for $50
Should be pretty straight forward and mount in your existing location.
~Dave~
4cstr is offline
post #4 of 9 (permalink) Old 08-05-2009, 04:33 AM
TwinStacks
SmknDzl's Avatar
If I recall right my hoses were diff sizes so I had a coupling with the size barbed fittings I needed screwed in on either side and then clamped them tight. Other than that bolts right up.
It helps a lot, you got a good deal.
Chris Cayer- www.facebook.com/SmknDzl or www.myspace.com/smkndzl send a request
Early '99 Black Lariat F-350 cclb dually-TS 6 position, AFE StageII, Autometer UltraLite Gauges, 6" Turnout Stacks, Muffler/Cat Delete, Built Trans from RacerX with .670 Line Mod Valve and Full LockUp Valve, 6.0L Trans Cooler, Boost Relief Valve, Oil X-Over, 5% Tint Around With 20% On The Windshield and 5% Strip On Top, Tinted Tail Lights, 2003 Clear Headlights, VisionX 8K H.I.D. Kit, JVC InDash DVD, APS997 Remote Start and Alarm, Painted Grille and Mirrors, WhiteNight Reverse Lights
Competition Cobra29, DaveMade Comp 2x2, 2x4 and 5pill boxes on VOLTS, Modified Wilson 5000...YEAH IM TALKING
Nathan Airchime P5 Train Horns @ 200PSI
SmknDzl is offline
post #5 of 9 (permalink) Old 08-05-2009, 04:36 AM
TwinStacks
SmknDzl's Avatar
yup, thats funny
SmknDzl is offline
post #6 of 9 (permalink) Old 08-05-2009, 06:28 PM Thread Starter
Kip
In the passing lane
Kip's Avatar
thanks for the info guys but Dave you crazy you said you would give $300 for it
Kip is offline
post #7 of 9 (permalink) Old 08-05-2009, 09:39 PM
edge186's Avatar
your welcome kip for that cooler by the way. im on my way out right now to try and install mine.
2001 Ford F-250 Superduty PSD
CC, SB, Auto
Power Hungry Performance
ATS Straight Pipe
ATS Ported Compressor Housing
AFE Stg II Intake
CCV Mod
Foil Delete
6.0 Trans Cooler
B&W Hitch
edge186 is offline
post #8 of 9 (permalink) Old 08-05-2009, 10:27 PM
4cstr's Avatar
Images: 35
I do have one already...just need to find the time to get it installed and get my factory and V10 cooler out.
~Dave~
4cstr is offline
post #9 of 9 (permalink) Old 08-07-2009, 08:51 PM
edge186's Avatar
i finally got mine installed yesterday. i originally used heater hose but decide i didn't wanna risk them not being strong enough so i replaced it with some better stuff.
CC, SB, Auto
ATS Straight Pipe
AFE Stg II Intake
CCV Mod
Foil Delete
6.0 Trans Cooler
B&W Hitch
edge186 is offline
Adapting oil cooler to trans cooler 4L80E. . . M123KT-450 GM Transmissions 16 08-15-2009 11:44 PM
Oil cooler install Spindrift 2003-2007 6.0L Power Stroke 3 07-03-2009 02:44 AM
Trans cooler OBS 97UTPSD 1994-2003 7.3L Power Stroke 5 04-30-2008 09:36 PM
new 6.0 trans cooler 02bigstrokin Whats Been Sold 9 02-08-2008 02:43 AM
WW, ATS housing, and Trans cooler install. JohnNolen 1994-2003 7.3L Power Stroke 0 08-29-2007 01:38 PM
