intercooler boot - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JoeDirte, this thread has received 2 replies and been viewed 1427 times.
post #1 of 3 (permalink) Old 08-05-2009, 09:51 AM Thread Starter
intercooler boot
I just spent some time changing out the HPOP fittings on the drivers side because I noticed an oil leak. I've checked on a daily basis and now I see a small puddle of oil in the valley. I thought the HPOP o-rings/fititngs were leaking, but they were not. It looks like I'm getting the oil from the bottom side of the intercooler boot. Why is there so much oil there in those pipes? The clamps are definitely tight. I guess I need to get a new boot. I took a look at the other boots and I'm wondering if I should change those. The longer ones in the front are a bit greased up, but that may be from years of grime. Where should I look to get the one replacement boot or would you guys recommend changing out the four intercooler boots and the ones under the spider?
2000 F250 Supercab 2wd, 6spd, DP Tuner, Southbend conFE, MBRP 4" turbo back straight pipe. DIY intake.
JoeDirte is offline
post #2 of 3 (permalink) Old 08-05-2009, 03:27 PM
The one and only
I would take them apart and clean them with break cleaner and put them back together and also do a CCV mod so that you are not getting oil into your intake and IC boots.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #3 of 3 (permalink) Old 08-05-2009, 03:27 PM
4cstr's Avatar
Images: 35
What happens is the CCV re-routes crank-case vapors back into the intake tract. These are oily vapors from the motor. The oil collects on the boots and in the intercooler itself...resulting in the oily boots. You can take the boots off and clean them out, but until you do the CCV mod...they will become oily over time.
~Dave~
4cstr is offline
Help, blown intercooler boot! honda450 1994-2003 7.3L Power Stroke 9 08-14-2009 03:34 AM
intercooler boot big_rooster 5.9L Cummins (1998.5-2002) 1 09-14-2007 01:03 AM
Intercooler boot sizes xtremexj 2003-2007 6.0L Power Stroke 8 07-24-2007 02:34 AM
intercooler boot Robts 2003-2007 6.0L Power Stroke 3 06-26-2007 06:43 AM
Intercooler boot set 6_Myles 1994-2003 7.3L Power Stroke 5 04-11-2007 04:42 AM
