maybe a boost leak? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by vader's fury, this thread has received 16 replies and been viewed 2742 times.
post #1 of 17 (permalink) Old 08-05-2009, 10:57 PM Thread Starter
beware the dark side
maybe a boost leak?
I got a turbonetics drop in turbo couple of weeks ago and put it in. While i was doing that i took out the intercooler, tubes, spider, and all the boots and cleaned everything up good. I have not been able to get more than 20# of boost out of her and i can get that at just over half throttle. i could only get 18 out of the stock turbo, that is one of the reasons i got the new turbo. also the truck smokes more now that it did when i had the stock turbo on it(esp at wot). Is this normal or any idea's what the problem might be.
2003 F-350 XLT 7.3L 4X4 Crew Cab, 3.73, Custom built 4R100, AFE intake, Turbonetics BB Turbo W/1.0 A/R exhaust housing, 238/100% Hybrids from Jim @ Rosewood, 5 inch exhaust w/ 6 inch stacks, Tuned my Matt @ Gearhead, Autometer colbalt gauges, Custom built traction bars, viair dual compressor onboard air system. Mickey Thompson Classic II Rims with 315/75R16 BF Mud Terrains, and 4 inch Rough Country lift kit
New Truck: 2000 F-450 XL 7.3L Standard Cab, 6 Speed Stock for now
Trailers: 1999 Jayco 30' 5th wheel
2004 Wells Cargo 20' enclosed trailer (portable shop)
Its not how fast you get there but how much you can pull on the way there.
vader's fury is offline
post #2 of 17 (permalink) Old 08-06-2009, 01:28 AM
pontiacross's Avatar
if you can the same thing at half throttle as full throttle you may need to adjust your wastegate a little.
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 17 (permalink) Old 08-06-2009, 02:51 AM Thread Starter
i thought of that too so i unplugged it completely and didn't see any diff.
post #4 of 17 (permalink) Old 08-06-2009, 08:46 PM
double check all your boots and tube connections. it took me a few tries to get all the leaks fixed when i did my turbo swap. I also built one of those pvc leak detectors that you hook to compressed air. it made finding leaks pretty easy.
2010 F250 6.4 - Stock
SOLD 2001 F250 7.3 Platinum Edition
Garrett Ball-Bearing Turbo/AFE Stage 2/AIH Plug/Sonnax/5" Exhaust/DP-TUNER Chip
R_S_C is offline
post #5 of 17 (permalink) Old 08-07-2009, 04:44 AM Thread Starter
i have one of those too. Tried hooking it up today but it never presses all the way up. was trying to go to about 20# and it steadily just keeps flowing air through the regulator. I can hear it coming out of the crank case vent but couldn't find any other place it was coming out of. I used a whole spray bottle of soap and water.
post #6 of 17 (permalink) Old 08-08-2009, 05:30 AM Thread Starter
is there a posibility that it is coming from the intercooler? I really cant spray the intercooler with soapy water without removing it from the truck.
post #7 of 17 (permalink) Old 08-09-2009, 06:17 PM Thread Starter
no idea's from anyone??? Well i am going to tear back into it today and hopefully find this problem. Could it be a tuning prob? I couldn't get more than 18# with the stock turbo, that is why i replaced it.
post #8 of 17 (permalink) Old 08-09-2009, 06:19 PM
make sure your u-pipes arn't leaking. an exhaust leak is just as bad as a boost leak
Ross
Tow Rig
post #9 of 17 (permalink) Old 08-10-2009, 03:46 AM Thread Starter
there was a little bit of black on the up pipes so i replaced the donuts when i put the turbo on and i dont see any more leaks when i look in there. i went through all my boots again but dont see any leaking
post #10 of 17 (permalink) Old 08-10-2009, 04:08 AM
is the truck smokeing? maybe you have other issues. if you dont have the fuel your suppost to have it woun't drive the turbo to make more boost
Ross
Tow Rig
Boost leak test kit? Foxx 1994-2003 7.3L Power Stroke 6 09-25-2007 02:20 AM
BOOST LEAK (i think) Okie2500 General Dodge Discussion 0 09-24-2007 01:39 AM
Oil Leak Or Boost Pressure Leak At Hot Side Charge Air Cooler (cac) Duct PSDPlayer 2003-2007 6.0L Power Stroke 2 01-12-2007 05:17 AM
I might have a boost leak imported_duck 5.9L Cummins (1998.5-2002) 2 10-20-2006 11:40 PM
Boost leak test rig... CSIPSD 1994-2003 7.3L Power Stroke 2 04-10-2006 04:42 AM
