turbo question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 4cstr, this thread has received 19 replies and been viewed 2499 times.
post #1 of 20 (permalink) Old 08-09-2009, 04:54 AM Thread Starter
4cstr's Avatar
Images: 35
turbo question
Now that I am looking into turbos (notice I didn't ask which was best ) I have seen some Garrets listed at various sites (our vendors mostly).
What is the difference between a GTP38, GTP38 Hybrid and a GTP38R other than the obvious prices?
~Dave~
4cstr is offline
post #2 of 20 (permalink) Old 08-09-2009, 05:22 AM
pontiacross's Avatar
I may be way off on this but I was thinking a gtp38 is a stock turbo, and gtp38 hybrid is a stock with the same wheels that a 38r runs, and the gtp38r is the ball bearing turbo.
hopefully some one will correct me if I am wrong
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
The Following User Says Thank You to pontiacross For this addition to TDG:
4cstr (08-09-2009)
post #3 of 20 (permalink) Old 08-10-2009, 02:18 PM
Diezel Dawg's Avatar
i think that sounds about right.
Ken
99.5 7.3L PSD 4x4
GTP38R BB TURBO
Casserly 250cc Hybrid injectors
BTS Trans W/ 6.0 Trans cooler
Live Tuned by Jody
TYMAR Intake/Coolant Filter
463hp and 912 tq 6 Feb 10
491hp 944tq 28 Aug 10
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Terminator Big Oil,
PNWFDE#2
Diezel Dawg is offline
post #4 of 20 (permalink) Old 08-10-2009, 02:26 PM
The one and only
Sounds right to me.
To my knowledge the other 2 can be rebuilt but the 38r can not be.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #5 of 20 (permalink) Old 08-10-2009, 03:06 PM
38 is stock, and uses the journal bearings.
38 "hybrid" is a rebuilt stocker with either a wicked wheel, larger turbine housing, ATS compressor housing, or any combination of those.... but still uses the journal bearings.
A 38R is the ball bearing.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
mrsweattmt (12-29-2010)
post #6 of 20 (permalink) Old 08-10-2009, 03:27 PM
Originally Posted by big_stroker View Post
Sounds right to me.
I thought the 38R could actually be rebuilt but since the parts are specific to that single model of turbo, they're correspondingly VERY expensive and so the charge to rebuild one is somewhat prohibitive compared to just buying a whole new one.
jvencius is offline
post #7 of 20 (permalink) Old 08-10-2009, 03:30 PM
The one and only
I don't even think you can buy the parts to rebuild a 38r but i could be wrong.
Dyno Sheet
post #8 of 20 (permalink) Old 08-10-2009, 03:33 PM
I could be wrong too, but I remember reading that little info-bit a few years back re: a 38R rebuild. IIRC the "rebuild" pretty much consisted of buying a whole new center section/shaft then bolting your wheels/housings onto it, unlike rebuilding a regular 38 where you re-use the center section and put in new bearings/seals.
jvencius is offline
post #9 of 20 (permalink) Old 08-11-2009, 05:53 PM
I dont think a person can rebuild a 38R, it has to be sent back to Garrett to be rebuilt. but the turbo is rebuildable.
Ken
99.5 7.3L PSD 4x4
GTP38R BB TURBO
Live Tuned by Jody
PNWFDE#2
post #10 of 20 (permalink) Old 08-11-2009, 07:32 PM
TDG Mafia Member # 37
01blkf250's Avatar
You sir are correct, I just went through this dilemma a couple months ago. The center section will run you upwards of $1500.00 and then you have to get it balanced. I went the Hybrid route with my old GTP38 stock turbo. I honestly can't tell any difference performance wise and I think it is actually slightly louder. dave I'll shoot you a PM where I got mine done up.
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
turbo question blackcloudCTD95 General Dodge Discussion 2 02-08-2009 01:51 AM
turbo question Stroker99 1994-2003 7.3L Power Stroke 3 01-19-2009 04:30 AM
turbo question...need help.. imported_BillM2004 5.9L Cummins (2003-2007.5) 1 12-14-2007 10:33 PM
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 04:35 PM
turbo question extreme_cummins 5.9L Cummins (2003-2007.5) 2 03-25-2007 03:20 AM
