Heavy Duty Transmission??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by RLSmith, this thread has received 11 replies and been viewed 3403 times.
post #1 of 12 (permalink) Old 08-09-2009, 07:56 AM Thread Starter
I have a 2001 F250 4X4 with the 7.3 and automatic tranny. We have had people in town rebuild it several times and each time they say it should hold up to anything but we keep having problems and burning them up. This truck does hurricane clean up and right now in texas it is hauling way more than it can handle and its a lot of off road in low range hauling. So now we have had enough and are looking for a tranny that can handle the job so i am looking for reccomendations on who can build me what I need. Im also looking for a set of injectors for a little more power and possibly better fuel milage.
Thanks Ryan
RLSmith is offline
post #2 of 12 (permalink) Old 08-09-2009, 08:01 AM
http://www.brianstruckshop.com
Brian (closer to you in Texas) and John Woods (out in CA) are pretty much a wash for being the cat's azz of 4R100 work...
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
RLSmith (08-10-2009)
post #3 of 12 (permalink) Old 08-09-2009, 04:56 PM
TDG Mafia Member # 37
01blkf250's Avatar
Give Bill at RacerX Automotive a call also. He is also a site sponsor. His number is 803-854-0040.
2001 F-250 XLT, cc sb 4X4, 3.73 LS,auto, Ported ATS shroud housing 1.00 exhaust housing Banks wicked wheel adjustable wastegated turbo,Non Ebpv pedestal and gutted Ebpv, DI Performance regulated fuel return kit, Dieselsites' 203* thermostat and billet housing, MBRP 4" ss turbo back exhaust system, AFE Stage 1 air intake, Jody Tiptons' F5 chip with no start,stock, 60hp tow,and 120hp race tune for now til I get big oil and injectors. Sonnax kit, Dieselsites' A/C heater core bypass valve, Autometer Boost, Pyro, and Trans temp guages in A pillar, Regulator in MAP line set at 20psi, boost tube, wastgate adjusted real tight, Aih delete, and Zoodad'ed. Amsoil fluids, Monroe Reflex shocks, and Ironman APR 265/75/16R tires.
01blkf250 is offline
The Following User Says Thank You to 01blkf250 For this addition to TDG:
post #4 of 12 (permalink) Old 08-09-2009, 09:33 PM Thread Starter
thanks for the info i will get in contact with these companies but i was wondering about ATS and BD Power and other manufacturers like that also
RLSmith is offline
post #5 of 12 (permalink) Old 08-09-2009, 09:43 PM
01blkf250's Avatar
When asking about trannys' you will get some heated debates, but most people agree on RacerX, BTS, or John wood. ATS has been known to provide some bad customer service for some and others say great service. I don't personally know anything about BD's trans a member here several years back used one of their TC's though and it held up pretty well for a while til his power started really climbing. He didnt go with them though when he got a new tranny. Call the mentioned parties and tell them what you are needing and decide from there.
post #6 of 12 (permalink) Old 08-10-2009, 05:06 AM
4cstr's Avatar
Images: 35
Yep...tranny opinions are one of those topics that can get heated very quickly.
In addition to what was mentioned above...Suncoast also builds a good unit I have heard. I have a Monsterbox with no issues.
One quick question. With every tranny rebuild you were going through...did they put a new cooler in? If you trashed your tranny the first time and it sent trash through the cooler...the cooler could be partially plugged. If they didn't replace the cooler with each successive rebuild...it makes sense that the tranny would die so quickly.
If you go with a full built tranny (RacerX, BTS, Suncoast, etc) be sure to get a new cooler installed to go with it.
~Dave~
4cstr is offline
post #7 of 12 (permalink) Old 08-10-2009, 01:58 PM
Cratos's Avatar
what ever you do DON"T get a Jasper!!!!!
Cratos is offline
post #8 of 12 (permalink) Old 08-10-2009, 02:13 PM
Diezel Dawg's Avatar
BTS or John Wood Transmissions, enuf said!
Ken
99.5 7.3L PSD 4x4
GTP38R BB TURBO
Casserly 250cc Hybrid injectors
BTS Trans W/ 6.0 Trans cooler
Live Tuned by Jody
TYMAR Intake/Coolant Filter
463hp and 912 tq 6 Feb 10
491hp 944tq 28 Aug 10
Future mods-- AirDog/ITP Reg Ret. Fuel sys. w/fuel bowl del, Terminator Big Oil,
PNWFDE#2
Diezel Dawg is offline
The Following User Says Thank You to Diezel Dawg For this addition to TDG:
RLSmith (08-11-2009)
post #9 of 12 (permalink) Old 08-10-2009, 03:07 PM
Quoted for emphasis.
Pocket is offline
The Following User Says Thank You to Pocket For this addition to TDG:
post #10 of 12 (permalink) Old 08-10-2009, 03:22 PM
1911 single stack
2fast2reid's Avatar
BTS
'08 2500 GMC LMM CCSB 4wd white, 1" rear block, and level kit on 285s...Fab Four replacement bumper....EFI live/4" Diamond Eye exhaust.
'06 F-250 Lariat 4wd CC SB 6.0 white/tan on bottom, cab lights 5% tint all the way around. Sometimes a Yakima kayak rack. SCT w/Cale's tunes, BTS 5R110 tranny, Hypermax stg 1 injectors, EGR delete, 5"MBRP w/out kitty.
512/916 @ BTS. SOLD
'02 F-350 Lariat 7.3 4wd CC SRW SB white cab lights matching tint on front windows, chrome brushguard. Cale's chip, BTS 4R100, Stock charger with 1.0 non wastegated exhaust housing, and Magnaflow 4".
'02 F-250 Lariat 7.3 4wd CC SB burgundy w/tan on bottom
STOCK for now.
2fast2reid is offline
The Following User Says Thank You to 2fast2reid For this addition to TDG:
citgo 10w heavy duty transmission fluid ???? goatwrangler Bio-Diesel/ULSD/Additives Discussions 2 03-05-2009 10:07 PM
Heavy duty tow ropes/straps? woodsman Towing and Hauling 5 02-12-2009 05:28 PM
2009 Heavy Duty ? MoPower05 6.7L Cummins (2007.5-2011) 7 03-07-2008 11:32 PM
Best Motor For Heavy Duty--?? FordRacing200 Medium and Heavy Duty 88 03-03-2007 06:21 AM
Heavy Duty Wreckers King of Obsolete Medium and Heavy Duty 1 10-27-2006 01:44 AM
