New to the 4r100 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by R33615, this thread has received 3 replies and been viewed 1373 times.
post #1 of 4 (permalink) Old 08-21-2009, 02:52 AM Thread Starter
New to the 4r100
I'm about to purchase a 99' f450 with a "broken" transmission. I'm not too familiar with the 4r100, anybody have any ideas of what may have failed in the tranny? I'm going to be using this truck to pull a heavy (18k) trailer and I want to rebuild the tranny strong enough to handle it. Just wondering if it could be input/output shafts, or most likely clutch packs... Thanks for the help.
'03 F250 CCSB SRW, SCT, K&N, MBRP STRAIGHT PIPED, SNOW STG 3, LIFTED 6" ON 37'S, RCD's EGR DELETE, AP HD200, TP STG 1 FUEL SYSTEM, HYPERMAX STG 1 INJECTORS, ARP'S, ID TUNED, VARIOUS LITTLE GOODIES...
R33615 is offline
post #2 of 4 (permalink) Old 08-21-2009, 05:00 PM
The one and only
Send it to Brian at BTS and you will never have any more issues with it.
If you don't want to do that then do what I'm doing. An Auto to Manual swap.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #3 of 4 (permalink) Old 08-21-2009, 05:15 PM
member
Images: 19
IMO, my first guess on the 99's would most likely be the converter and/or the clutch packs. I guess it could've been one of the shafts but not knowing the mileage or how it was used before you bought it, it's hard to say..If you know you're going to be beating on it or towing alot of weight all the time, it will benifit you to upgrade all the internals before hand anyway.. Which I'm sure you were planning already..
I was lucky and caught mine this April before catastrophic failure. And it was the converter and packs, while they had it down we upgraded all the internals, bigger tranny cooler and torque converter..
Good luck and keep us updated....
CrawfishPSD is offline
post #4 of 4 (permalink) Old 08-22-2009, 04:52 AM
Racer X's Avatar
Not enough info to make an educated guess. Therefore, count on the worst. Good luck & welcome!
POWERFLOW BY RACER X on Video. Featuring Ford's 7.3L Powerstroke Diesel with custom E4OD Transmission. Powered by custom twin turbo chargers and custom fuel system injecting 473 + cc's of diesel & nitrous @ 800 r.w.h.p!
Racer X is offline
4R100 wireing. Macktruckdriver 1994-2003 7.3L Power Stroke 4 04-22-2008 03:18 AM
4R100 Rebuild StrokerDude 1994-2003 7.3L Power Stroke 2 03-29-2008 11:47 PM
4r100 help ford7.3sd 1994-2003 7.3L Power Stroke 14 02-29-2008 01:56 AM
4r100 Robts 1994-2003 7.3L Power Stroke 7 10-10-2007 05:38 AM
4r100 Bluemonster 1994-2003 7.3L Power Stroke 5 04-17-2006 05:00 PM
