2002 7.3 - Check engine light and rough running - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Rev J Wright, this thread has received 30 replies and been viewed 12312 times.
post #1 of 31 (permalink) Old 09-10-2009, 04:32 AM Thread Starter
Guys,
This weekend my check engine light came on and the truck started running rough when given any throttle. I took it to a local shop and the mech hooked up his computer and got a code(i think it was 1277) that indicated some electrical issue feeding the #7 cylinder. He replaced the wiring to the injectors on that side of the engine and it didn't help. When the truck is cold it runs fine and no engine light. After running 10-15 minutes, the light goes on and vibration starts. On the way home this afternoon the light actually went off and ran smooth for a few seconds then the light came back on and the shaking started again. Could this be an injector? Any suggestions would be greatly appreciated.
Tim
2002 F250 Crew 4x4 (everything is stock)
Rev J Wright is offline
post #2 of 31 (permalink) Old 09-10-2009, 04:58 AM
plainredtruck's Avatar
Images: 11
Can you have the shop run a cylinder contribution test?
That would tell you if an injector is being problematic.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 31 (permalink) Old 09-10-2009, 05:37 AM Thread Starter
I'll check on that. Thanks!
Tim
post #4 of 31 (permalink) Old 09-10-2009, 07:02 AM
sure sounds like a sticky injector.
kainers is offline
post #5 of 31 (permalink) Old 09-10-2009, 07:36 PM Thread Starter
Guys,
Thanks for the input. I talked to the mechanic a few minutes ago and after more study, he suggested the possibility of a problem with the computer(I apologize for not knowing the proper acronym) in the truck which would require reprogramming at the least or a new computer all together. If so it will require a trip to the dealership. If the mech is correct, how much money should I expect to see to reprogram and how much to replace?
Tim
post #6 of 31 (permalink) Old 09-10-2009, 07:55 PM
SmokeCloud's Avatar
Originally Posted by Rev J Wright View Post
Guys,
Tim
If its your computer and since its a 7.3l its an IDM. Injector drive module.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #7 of 31 (permalink) Old 09-10-2009, 08:09 PM
Guys,
Tim
You can't reprogram an IDM at the dealer.Your PCM doesn't need programming.You need to find another mechanic that knows diesel specifically 7.3 powerstroke with HEUI injection system.
kainers is offline
post #8 of 31 (permalink) Old 09-10-2009, 08:18 PM Thread Starter
Thanks for the input! Any suggestions on a knowledgeable mechanic in SW Arkansas or NW Louisiana?
Tim
post #9 of 31 (permalink) Old 09-10-2009, 08:30 PM
Iam not from that area so I'am of no help.It really really sounds like an injector.
When was the last time you changed the Oil?
kainers is offline
post #10 of 31 (permalink) Old 09-10-2009, 08:33 PM Thread Starter
I changed the oil about 2000 miles ago.
#08-06-04-054: Snow Intrusion into Air Cleaner, Check Engine Light On, Engine Reduced ripmf666 GM TSB Info 0 08-10-2009 05:46 AM
running problems with check engine light on 1995nicholas 1994-2003 7.3L Power Stroke 3 04-01-2009 01:52 AM
Check Engine light on & rough running dieselbrad 1994-2003 7.3L Power Stroke 2 10-31-2007 12:49 AM
Engine running rough Roughneck 5.9L Cummins (2003-2007.5) 15 05-25-2007 08:38 PM
engine running rough fordrules75 1994-2003 7.3L Power Stroke 0 11-06-2006 01:59 AM
