Check engine light, runs bad, turn key off then on, runs fine? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Stevie Mac, this thread has received 10 replies and been viewed 2754 times.
post #1 of 11 (permalink) Old 09-15-2009, 11:42 AM Thread Starter
2000 7.3 with about 15psi boots upon exceleration the truck starts to sputter.
This feels like an injector, but would turning the key on and off make it run fine if it is injector?
Once the check engine code is clear the rough running clears.
Stevie Mac is offline
post #2 of 11 (permalink) Old 09-15-2009, 01:01 PM
The one and only
Why don't you tell us what the code is you are getting.
Could be lots of things.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #3 of 11 (permalink) Old 09-15-2009, 05:15 PM Thread Starter
Guess I would need to catch it while code is hitting.
I took to autozone and the check engine light on, but reader picks up no code.
Is an autozone code reader good enough?
post #4 of 11 (permalink) Old 09-15-2009, 05:19 PM
The one and only
nope you have to have something like AE to scan our trucks.
Where do you live?
Dyno Sheet
post #5 of 11 (permalink) Old 09-16-2009, 11:08 AM Thread Starter
I am in Joplin, MO area.
post #6 of 11 (permalink) Old 09-16-2009, 02:29 PM
SmokeCloud's Avatar
First off you shouldn't have cleared the code, we would be able to point you in a better direction if you tell us the code? next time it pops up write it down and post it here, until then we can help you much but make guesses.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #7 of 11 (permalink) Old 09-17-2009, 12:44 PM
The one and only
Are you really that dumb?
READ for a change. He don't have a way to read the codes.
Dyno Sheet
post #8 of 11 (permalink) Old 09-18-2009, 02:31 AM
SmokeCloud's Avatar
This
You said something similar relax man.
post #9 of 11 (permalink) Old 09-18-2009, 12:51 PM
The one and only
yeah b4 he said the only way he had to read them was AutoZone.... And there code readers aren't good enough to see the codes.
LEARN TO READ!!!
And you don't even own a diesel or worked on one so only thing you know are what you half *** read on the forums. And I'm getting tired of your dumb posts to be honest.
Dyno Sheet
post #10 of 11 (permalink) Old 09-19-2009, 04:26 PM
dieselman723's Avatar
If i'm not mistaken that sounds like a bad cps
2011 Silverado 3500 HD Duramax/Allison Stock for now lol
'06 Suzuki LT 450R Quadracer, Cherry Bomb Power Module, Spark Arester Delete, Air Box Lid Delete
dieselman723 is offline
Truck runs fine only when I add power service Horn399 2003-2007 6.0L Power Stroke 10 07-14-2009 09:32 PM
engine barely runs and there is tons of white smoke BobM 5.9L Cummins 12 Valve (1994-1998.5) 18 04-20-2008 04:23 PM
engine runs then stalls sgowan 1994-2003 7.3L Power Stroke 1 07-02-2007 04:56 PM
weird trouble codes, engine runs rough Powersmoker113 1994-2003 7.3L Power Stroke 0 05-25-2007 02:04 AM
Check out this little model motor which runs slowford The Parking Lot 7 12-28-2005 02:27 AM
