need help tranny wont shift - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by cong, this thread has received 12 replies and been viewed 1760 times.
post #1 of 13 (permalink) Old 09-22-2009, 03:12 AM Thread Starter
have a 2000 f250 auto and It did have a chip on it before and it was shifting hard before this happen. I can't get my tranny to **** out of 2 gear it like stuck and my speedometer is going crazy like up to 35 than down to 15 , I had the problem not shifting before but it went away because it was low on trany fluid because i had a hole in my trany cooler line
I did have time to check it out because I had to go to work going on 2 gear cuss im in college and this is my only truck, but I think mabe the speed sensor.
can my ecm be bad? how would I know?
cong is offline
post #2 of 13 (permalink) Old 09-22-2009, 07:34 PM
SmokeCloud's Avatar
Do you find it hard to get out of gear?
Real Trucks Burn Diesel!
SmokeCloud is offline
post #3 of 13 (permalink) Old 09-22-2009, 09:42 PM Thread Starter
It wont shift up over 2 gear
cong is offline
post #4 of 13 (permalink) Old 09-23-2009, 12:42 AM
SmokeCloud's Avatar
sounds like a torque convertor.
post #5 of 13 (permalink) Old 09-23-2009, 02:00 AM
trackspeeder's Avatar
Fix the VSS in the rear end.
01 F250 4X4, 7.3.
90 F350 4X4, 7.3
85 F250 4X2 6.9
08 Arctic Cat 700 4X4, Diesel
Easy button for photos
trackspeeder is offline
post #6 of 13 (permalink) Old 09-23-2009, 06:37 PM Thread Starter
well today it drove fine like nothing happen, I don't know why
cong is offline
post #7 of 13 (permalink) Old 09-23-2009, 07:25 PM
member
Images: 19
Adding to what said..Do you have 2wd or 4wd??? If you have 4wd there's one on the front as well..
CrawfishPSD is offline
post #8 of 13 (permalink) Old 09-24-2009, 01:51 PM Thread Starter
I have 4wd. I look at the back one and did see anything wrong, no gunk, I will look at the front one today thanks alot guys
cong is offline
post #9 of 13 (permalink) Old 09-24-2009, 05:24 PM
The one and only
honestly a TC???? Explain to my how and why a TC wouldnt let the tranny shift out of 2nd?
Anyway. Glad it is working for you now. It also could have been a stuck valve or diode.
But since the speedo was acting up the VSS could be an issue also
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #10 of 13 (permalink) Old 09-24-2009, 05:43 PM
99_stroker's Avatar
VSS??? thanks
Grein,
1999, ford f-250 superduty cc, lb, diy intake, dp tuner, 3 gauge pillar, tint all the way around, gto smoked heads and tails, uniden cb, recon smoked cab lights, recon running lights, recon third brake light
99_stroker is offline
transmission wont shift! cowboyupp16 GM Transmissions 3 02-03-2008 04:17 PM
tranny wont shift moprr71 5.9L Cummins (1998.5-2002) 0 06-26-2007 02:27 AM
7.3 1-2 shift error reading, TDS wont help, can yall? George the Dog 1994-2003 7.3L Power Stroke 69 03-06-2007 11:29 PM
auto wont shift unless you let off gas, or bring to redline charkly 1994-2003 7.3L Power Stroke 13 12-03-2006 07:32 PM
