Rear diff Oil question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by keystone cop, this thread has received 7 replies and been viewed 2206 times.
post #1 of 8 (permalink) Old 09-24-2009, 03:04 PM Thread Starter
I have a Dana 3.73 rear end with these numbers on the tag 606775-1. According to my owners manuel it states I am supposed to use 80w90 gear oil. Do i need to ad the rear diff suppliment, and also is this the correct oil to use? I used Lucas oil when i replaced it is this ok?
keystone cop is offline
post #2 of 8 (permalink) Old 09-24-2009, 04:27 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
That weight is a little light Ford is not recommending that weight any more and an friction modifier is needed. You need to know a little more about the rear end Go here we use all manufactures recommendations.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #3 of 8 (permalink) Old 09-24-2009, 04:35 PM
Mod Friendly Title
Zaairman's Avatar
You need 75w140 and some diff fluids have the friction modifier already in it. I used Royal Purple which has it in it already. Good stuff.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #4 of 8 (permalink) Old 09-24-2009, 05:18 PM
The one and only
When i changed mine I used AMSOIL 75w140 and about 2 oz of friction modifier.
The reason I used 2 and not the recommended 4 is because that is what felt good to me.
I had problem with the limited slip not working so I changed the fluid and drove it. and added an oz of the stuff till it felt and drove good to me.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #5 of 8 (permalink) Old 09-24-2009, 05:57 PM
Amsoil does state the modifier may not be needed it is as needed your approach is a sound one I just added the 4oz just to keep from doing any damage.
Bill
5" SS Tip
post #6 of 8 (permalink) Old 09-24-2009, 07:32 PM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
Bill
Bill, is that the link you really wanted to post? I didn't see anything about oil in there.
Just wondering.
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
The Following User Says Thank You to CFRO For this addition to TDG:
CrowsSynthetics (09-26-2009)
post #7 of 8 (permalink) Old 09-24-2009, 07:49 PM
Just wondering.
Your are right that is not the right link here it is. I don't know what happened.
Thanks Bill
5" SS Tip
post #8 of 8 (permalink) Old 09-26-2009, 03:48 AM
4cstr's Avatar
Images: 35
I also use the Amsoil in the front and rear diffs...and have been satisfied with it. I normally didn't run with the modifier in there, but the last camping trip I got a lot of rear end chatter loaded when turning corners. I have since added 4ozs of modifier...but haven't been camping to see if it solved the issue.
~Dave~
4cstr is offline
The Following User Says Thank You to 4cstr For this addition to TDG:
rear diff question Scubba 5.9L Cummins (1998.5-2002) 3 05-15-2009 04:08 PM
99 F-250 rear diff Macktruckdriver Whats Been Sold 7 02-11-2009 12:00 AM
Rear Diff fordfanatic69 2003-2007 6.0L Power Stroke 23 01-04-2009 01:19 AM
rear diff 2tonePSD 1994-2003 7.3L Power Stroke 36 12-31-2008 03:40 AM
Rear Diff on '05 2wd juiced305diesel 2003-2007 6.0L Power Stroke 2 02-11-2008 02:33 PM
