Put My 7.3 on the Dyno - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BillsFan, this thread has received 19 replies and been viewed 6926 times.
post #1 of 20 (permalink) Old 09-27-2009, 06:02 AM Thread Starter
BillsFan's Avatar
Took my truck to a show/dyno today. I learned two things...
1. As big as my truck seems to me on a daily basis, there are many that are much bigger.
2. Diesels can make some serious power.
Mine not have been the biggest or nearly the most powerful but it sure looked nice on the dyno.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #2 of 20 (permalink) Old 09-27-2009, 06:10 AM
*^%$#@&am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;am p;!! !!!
AUSSIEDAVE's Avatar
cool
i need to get mine on the dyno
FORD AUSTRALIA 2003 F350 DRW FLATBED
SUPERDUTY XL SUPERCAB 4X4 7.3 PSD 6 SPEED MANUAL GARRETT GT38R TURBO BANKS TECHNICOOLER 4 INCH DOWN PIPE AND MITRED STACKS DP TUNER GEARVENDORS OVERDRIVE ALCOA HOTSHOTS CUSTOM INTAKE
FORD AUSTRALIA 2007 RANGER
XLT CREWCAB 4X4 DP
INLINE 4 CRD TURBO DIESEL 3.0L 5 SPEED MANUAL
33MPG DP CHIP
SOLD FORD AUSTRALIA 2002 F250 FLATBED
SUPERDUTY XL SUPERCAB 4X4 I6 4.2L MWM TURBO DIESEL ZF5 SPEED 23MPG 425FT/LBS @1500RPM
http://www.youtube.com/watch?v=7FrJu...e=channel_page
www.myspace.com/skyzakyte
AUSSIEDAVE is offline
The Following User Says Thank You to AUSSIEDAVE For this addition to TDG:
BillsFan (09-27-2009)
post #3 of 20 (permalink) Old 09-27-2009, 06:18 AM Thread Starter
BillsFan's Avatar
Thanks, it was pretty cool even though the dyno was 1/2 broken. Everyone's torque reading was 1200.
Some guys were complaining that their horsepower was reading low also based upon previous dyno's.
But overall it was a cool experience, I recommend it.
Ridin' Dirty #64
BillsFan is offline
post #4 of 20 (permalink) Old 09-27-2009, 06:25 AM
Dyno's are intersting, some give high readings and some give low readings
crazycracker is offline
post #5 of 20 (permalink) Old 09-27-2009, 06:37 AM Thread Starter
BillsFan's Avatar
This is me waiting in line. I told my friend that after posting such a low number Dale would repo my Tymar Performance sticker.
Ridin' Dirty #64
BillsFan is offline
post #6 of 20 (permalink) Old 09-27-2009, 02:28 PM
4cstr's Avatar
Images: 35
what setting did you have your edge set at?
~Dave~
4cstr is offline
post #7 of 20 (permalink) Old 09-27-2009, 03:22 PM
CrowsSynthetics's Avatar
Send a message via Yahoo to CrowsSynthetics
They seemed a little low for your truck. Did you take it out of overdrive? Did you wait for it to get to high gear before you romped on it? These thing can make a difference. The type of dino also can affect the numbers I still am not clear on that.
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
Amsoil 3000 5w 30 ,Amsoil EaAU Air Filter ,Amsoil Pre filter-EaPF13,
Amsoil Dual Remote By-pass BMK-16A, Amsoil ATF & Transfer case, Amsoil 75w-140 fluid front & rear end, Amsoil Antifreeze Fluid
Edge with Attitude, 4" Turbo Back Exhaust,
5" SS Tip
, Transmission Magnefine filter, Sportman Tonneau Cover & Bush Fender Flairs
Now in the stable a new Black 2009 Jetta Sedan TDI
CrowsSynthetics is offline
post #8 of 20 (permalink) Old 09-27-2009, 03:49 PM Thread Starter
BillsFan's Avatar
For this I had my Edge on setting 3 - Extreme +100 HP.
I don't know what the operator did. Some of the guys were saying he wasn't letting the turbo's build enough boost.
I thought it seemed a little low also as the truck is rated at 275 stock but who am I to argue?
Ridin' Dirty #64
BillsFan is offline
post #9 of 20 (permalink) Old 09-27-2009, 05:02 PM
I believe the factory HP rating is at the Flywheel But you should be 300 -325 IMO with 4" exhaust and your after market intake the 100hp of edge my be rated at the flywheel as well.
Getting the truck in high or locking the toque converter is what you want to do from what I have been told. I use to have a JT tune and when you shifted out of OD it locked the TC up that was nice for a lot of applications.
Bill
5" SS Tip
The Following User Says Thank You to CrowsSynthetics For this addition to TDG:
post #10 of 20 (permalink) Old 09-27-2009, 05:49 PM Thread Starter
BillsFan's Avatar
Thanks Bill, I was hoping to break the 300 mark. Regardless of the dyno results I'm very happy with the power/performance of my truck. It's a 7700lb rocket!
Ridin' Dirty #64
BillsFan is offline
Dyno day MOPAR MAN Southwest 0 01-16-2009 09:48 PM
How to dyno? Snake 2003-2007 6.0L Power Stroke 11 05-08-2007 03:56 AM
DYNO #'s Morpheus cycles 2003-2007 6.0L Power Stroke 54 05-03-2007 05:04 PM
Dyno Results for OKC dyno day (finally!) twildman General Ford Truck and Excursion 20 04-06-2006 04:15 AM
St. Louis MO DYNO day is a GO!!! Nov 19th, (LOAD DYNO) Tomeygun Events and Gatherings 16 11-27-2005 05:01 AM
