HPOP Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3FordPower, this thread has received 6 replies and been viewed 1471 times.
post #1 of 7 (permalink) Old 09-28-2009, 04:31 PM Thread Starter
7.3FordPower's Avatar
HPOP Question
I am thinking about getting Adrenaline HPOP and seeing how it would help my truck out. What is all involved with changing a HPOP (How hard is it. Special tools, Time it takes.) things like that, if anyone has any information I would appreciate it.
96 F250 regular cab long bed 4x4, 176,000, 4inch exhaust with 6''x24'' tip, Gauges (boost, pyro, tranny temp) DIY intake, Dp-tuner F5 (80echo, 120hp, 140hp, 60 tow, lope idle) 33x12.5 BFG AT's on eagle rims with a front leveling kit. And to many lights on it.
7.3FordPower is offline
post #2 of 7 (permalink) Old 09-28-2009, 04:48 PM
MAFIA #8
hhrecovery's Avatar
Images: 1
pretty simple and straight forward to install.. no special tools are needed..
2003 F250 "Pulling Truck"
hhrecovery is offline
post #3 of 7 (permalink) Old 09-28-2009, 05:19 PM Thread Starter
thats what I like to hear. Do I have to move my stock fuel bowl If I put the Adrenaline HPOP in my truck.
post #4 of 7 (permalink) Old 09-28-2009, 06:48 PM
you have to take it out when you do the change but it piggybacks on the reservoir so its no big deal. you dont have to relocate it though if thats what youre asking........
indyF-350psd is offline
post #5 of 7 (permalink) Old 09-28-2009, 08:00 PM
Bob has instructions linked off of the Adrenaline section on his site--check 'em out and they might be helpful
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
Deputydog (09-29-2009)
post #6 of 7 (permalink) Old 09-29-2009, 03:08 PM Thread Starter
thanks for all the help. Thats what I all wanted to know
post #7 of 7 (permalink) Old 09-30-2009, 02:50 PM
Cratos's Avatar
Adrenaline seemed to quiet down my stage ones and smoother power band.
tourq the mount bolts (10mm) to 18 ft pounds and the gear bolt to 95 ft pounds make sure the gear is on stright.
I did the res filter block and these bolts are 18 ft pounds also. you will need to make a bracker for the pack pressure sensor but no big deal i can send you photos it you need them.
2012 f-240 lbsc 4x4
Cratos is offline
My Next hpop question 4cstr 1994-2003 7.3L Power Stroke 4 01-31-2009 04:21 AM
HPOP question Macktruckdriver 1994-2003 7.3L Power Stroke 1 02-14-2008 11:39 PM
Another HPOP question. coreystroke02 1994-2003 7.3L Power Stroke 5 04-05-2007 04:16 AM
Another HPOP question blackedoutsd 1994-2003 7.3L Power Stroke 15 02-23-2007 05:15 PM
question about HPOP??? dzljon 1994-2003 7.3L Power Stroke 5 01-01-2007 05:11 AM
