only 72,000 miles - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Buckshot341, this thread has received 9 replies and been viewed 1420 times.
post #1 of 10 (permalink) Old 10-04-2009, 02:25 AM Thread Starter
Tow Mater
only 72,000 miles
I got 72,000 on my truck in my sig, this morning went to go start her up and no go, just bellowed white smoke, so I started with checking the gpr, that checked out fine, after that noticed the coolant level was very low, from there checked the oil and thats very high, so its making oil and loosing coolant and a good guess is the coolant is going to the oil. i pulled the fuel filter all checked out good, so while i was in there dumped a little diesel 911 in cuz it got to freezing last night, it fired, died with a poof of blue and lots of white again, tried one more time and it fired and ran horidly running rough sounds like it may be missing too, then took it for a spin, nothing but blue smoke and zero power, once i got it up to op temps shut it down and it shut down hard. what yall think it is? Im guessing it has something to do with the coolant in the oil put how where what why?
*TOW MATER* 2010 F-350 crew cab long box single wheel, go recon running lights and a few other little things, more to come...
Singles member #208
BOMB Squad member #35
Buckshot341 is offline
post #2 of 10 (permalink) Old 10-04-2009, 03:23 AM
plainredtruck's Avatar
Images: 11
Injector cups, most likely.
Don't try to start it until you get the issue resolved.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 10 (permalink) Old 10-05-2009, 04:35 PM
The one and only
Sound JUST like what happend to my truck when It cracked both heads and all 8 pistions.
And wow you are running DP Tunes. 80E most the time I bet right?
Have fun.
On Edit: Injector cups more than likely would cause oil in coolant since the oil pressure at the cup is LOT higher then coolant pressure would be.
Blown HG or cracked head would more than likely be the issue.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #4 of 10 (permalink) Old 10-05-2009, 04:57 PM
Images: 11
So which is it? Oil cooler issue? Cracked injector cups? Injector o-rings?
Trey, did you make up your mind yet?
Oh wait, it has to be major engine issues associated since he just happened to be running tunes from someone you don't like.
Truth is, it could be any one of a number of issues from really bad fuel to injector problems to major engine damage (doubtful, though) caused by any other number of things.
Buckshot, get it to a shop that can get to the bottom of it if you don't feel comfortable diagnosing the problem; but by all means let us know what you find.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #5 of 10 (permalink) Old 10-05-2009, 05:05 PM
The one and only
Dude what is your deal with me?
I just think its funny that i have seen more then one motor have this issue running DP Tunes. Never said it was the issue did I?
Let me explane this so you understand.
Coolant in oil - Head Gasket or Cracked head.
This can not happen with a crack injector cup because the oil pressure is higher than coolant pressure. And if it was happening that way it would be VERY slow doing so and would probably hydrolock the cylinder.
Oil in coolant - Oil Cooler O-Rings OR injector cup since the oil pressure IS higher than coolant pressure.
Go read again.
But yes it could be a NUMBER of things.
Dyno Sheet
post #6 of 10 (permalink) Old 10-05-2009, 05:27 PM Thread Starter
Tow Mater
I am comfortable diagnosing it, but my time constraints suck, going to school for diesel and also working after school at a place called prostop doing rebuilds maint. and so on and so forth on class 8otr trucks, gone from home from 5am-11 at night, only time I got is weekends. it is at the stealership now because it is still under warranty just waiting to see what they have to say on it. And yes I did run the 80e, there was no warning to this just happened
Singles member #208
post #7 of 10 (permalink) Old 10-05-2009, 05:32 PM
The one and only
The dealership will warranty it even though you are running the DP? That must be nice.
Mine was the exact same way when it happend. Still ran fine just had green oil. I ran a leak down test, presser test of all 8 cylinders and i pressureized the coolant and still could find out what was wrong it all came back good.
I finally pulled the motor. Head Gaskets where good but i had the heads pressure tested and magnifluxed and they where both cracked all over. Also all 8 pistions where cracked... But that didnt have anything to do with the coolant in the oil.
I hope you find out what the issue is and its not to hard to fix.
Dyno Sheet
post #8 of 10 (permalink) Old 10-05-2009, 05:58 PM
dzljon's Avatar
Have fun.
99.5 F250, VGT 5.9 CR cummins
dzljon is offline
post #9 of 10 (permalink) Old 10-05-2009, 11:54 PM
CSIPSD's Avatar
Warranty on a 2001??? How so? Your out of warranty my friend.
CSIPSD is offline
post #10 of 10 (permalink) Old 10-06-2009, 04:07 AM Thread Starter
Tow Mater
was an extended warranty I took out when I bought the truck 3yr 36,000 mile deal
Singles member #208
10,000 miles imelmo 2003-2007 6.0L Power Stroke 4 01-09-2009 05:29 AM
How many miles do you have? mike141 5.9L Cummins (2003-2007.5) 15 05-25-2007 09:28 PM
how many miles is too many? mikeym 1994-2003 7.3L Power Stroke 15 03-19-2006 02:49 AM
How many miles with SCT? Wildcat 2003-2007 6.0L Power Stroke 7 03-02-2006 03:41 PM
Just hit 30K miles, and... Kawis Dad 2003-2007 6.0L Power Stroke 27 02-13-2006 09:57 PM
