99 f450 fuel? problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Navy_Seabee_CM, this thread has received 4 replies and been viewed 1964 times.
post #1 of 5 (permalink) Old 10-23-2009, 02:08 AM Thread Starter
dagon dagon!
so the 99 f450 is giving me problems, it will drive around town all day long without a problem, I will get on the highway and after 5-10 miles at 60-70 mph it will suddenly bog down and start to lose power and just do about 20-25 mph until i shut it off for ~30 min, then start it and it will drive like normal again. would this be a fuel problem electronic problem or something Im not seeing here? my buddy says bad injectors, but I doubt that as i would think that is a constant issue
97 Ram 3500 2wd dually 12v ff #0 fuel plate, upgraded compressor wheel, nv 4500 rock crusher, 4.10 rear gooseneck & 5th wheel hitch... also has access to underbed repo wheel lift
94 Chevy silverado Blazer 4X4, 350, 700r4, sound system from hell... still drive the dodge mostly
US navy construction & tactical vehicle fleet -Seabee and proud of it!
Navy_Seabee_CM is offline
post #2 of 5 (permalink) Old 10-23-2009, 02:45 AM
How old is the fuel filter?
Your EBP valve might also be sticking--that could explain the gutless throttle and bogging down. Last October when I had my turbo off I put on a high-flow turbine outlet and non-EBPV pedestal so that little "problem" will never happen again.
jvencius is offline
post #3 of 5 (permalink) Old 10-23-2009, 04:22 AM Thread Starter
dagon dagon!
filter is brand new, replaced it when problem started
post #4 of 5 (permalink) Old 10-23-2009, 04:31 PM
I have a friend that has the same truck and was having the same symptoms as you. After looking at it found that the 450's with the tank in the rear are known for the sending unit in the tank to have problems. There is a valve that regulates the fuel to be recirculated to the fuel bowl for cold weather conditions. The valve sticks and you loose fuel pressure. I replaced the sending unit assembly and now it runs like a top.
If i had to bet i would put my money on that.
Alex
03 f250 FX4 55,000 miles
-stock
99 F-350 4x4 CC LB 250,000 miles
-leveled w/ 315-75-16's
-4'' dp to 5'' stack
-CAI
-bullydog 6 pos
-D66 turbo
Stroked383 is offline
post #5 of 5 (permalink) Old 10-23-2009, 07:26 PM Thread Starter
dagon dagon!
well I'll definitely give it a try
99 f450 starving for fuel squishy 1994-2003 7.3L Power Stroke 9 06-13-2009 06:18 AM
2008 F450 A/C problem allenG 2008-2010 6.4L Power Stroke 2 07-06-2007 02:41 PM
fuel problem with 97 f-350 josh 1994-2003 7.3L Power Stroke 9 05-23-2007 07:41 PM
Fuel Pressure Problem? Lift problem? Going on long trip this weekend! JaredMTFD 5.9L Cummins (1998.5-2002) 4 01-24-2007 04:35 PM
