Exhaust smell from heater vents - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by classic, this thread has received 6 replies and been viewed 4028 times.
post #1 of 7 (permalink) Old 10-28-2009, 09:35 PM Thread Starter
classic's Avatar
I just bought an 01 F 250 with the superchips flash paq tuner and no other performance mods(that I can see). I have noticed an exhaust smell in the cab when I turn the heat on. Any ideas on what the problem could be?
classic is offline
post #2 of 7 (permalink) Old 10-28-2009, 10:33 PM
Leaky uppipes?
jvencius is offline
The Following User Says Thank You to jvencius For this addition to TDG:
classic (10-29-2009)
post #3 of 7 (permalink) Old 10-28-2009, 11:25 PM
Tow Mater
more than likely up pipes check all your clamping areas for leaks if your smelling it in the cab with the heater on most likely in engine compartment... Get that taken care of asap because that will kill you if it is bad enough and you are in there long enough with no ventilation
*TOW MATER* 2010 F-350 crew cab long box single wheel, go recon running lights and a few other little things, more to come...
Singles member #208
BOMB Squad member #35
Buckshot341 is offline
The Following User Says Thank You to Buckshot341 For this addition to TDG:
post #4 of 7 (permalink) Old 10-29-2009, 03:34 PM
HalfAst Racing
skippy's Avatar
Images: 1
it will hurt the performance of the truck too.best time to check em is when the ebv is on.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
The Following User Says Thank You to skippy For this addition to TDG:
post #5 of 7 (permalink) Old 10-29-2009, 10:44 PM Thread Starter
classic's Avatar
The truck has been a little sluggish lately, I just didn't get around to checking that out yet. Two birds with one stone, sounds good to me. Thanks
classic is offline
post #6 of 7 (permalink) Old 10-29-2009, 11:11 PM
There's not a huge amount of diagnosis you need to do--simply check around the manifold-to-uppipe and uppipe-to-collector (might need a mirror on a stick if there's a small leak there) joints to see if there's any soot accumulation. Those joints shouldn't leak at all, so if you see soot buildup, R/R'ing the uppipes is one more thing to add to your "to-do" list.
jvencius is offline
classic (10-30-2009)
post #7 of 7 (permalink) Old 11-01-2009, 10:52 AM
It's worse for the driver than the truck... you're being poisoned with exhaust. Had the same problem on my rig last year. I couldn't understand why I was getting these bad headaches and fatigue when driving long distances, but I had no exhaust smell. Git r done ASAP!
Lord_Zarkon is offline
fuel problems and smell through vents kasendaddy08 Duramax 07.5-2010 (LMM) 3 03-27-2009 03:13 AM
Exhaust smell in cab JoeDirte 1994-2003 7.3L Power Stroke 4 12-27-2008 05:24 AM
Exhaust smell Bcarriveau 2003-2007 6.0L Power Stroke 5 04-03-2008 02:52 PM
diesel smell thru the vents fastgreek Duramax 2004.5-2005(LLY) 12 12-21-2007 11:36 AM
Heater Smell hhrecovery General Ford Truck and Excursion 3 01-24-2006 06:49 AM
