Truck keeps shutting off - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sawed Off, this thread has received 9 replies and been viewed 2435 times.
post #1 of 10 (permalink) Old 10-29-2009, 10:51 PM Thread Starter
Sawed Off's Avatar
My service truck at work keeps on dieing all of a sudden. You take it down the road and she shuts off and the service engine soon light comes on. The truck is a 00 F-350 with the 7.3 bone stock. Guys have any ideas??
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
20" predator8 wheels
Toyo AT's
Rip 06 6.0 You were a great truck and will be missed
Sawed Off is offline
post #2 of 10 (permalink) Old 10-30-2009, 04:30 AM
UGH.
welcome to my world.
XRIADEDJ is offline
post #3 of 10 (permalink) Old 10-30-2009, 05:04 AM
CPS
jvencius is offline
post #4 of 10 (permalink) Old 10-30-2009, 07:35 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
hows the oil level?
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #5 of 10 (permalink) Old 10-30-2009, 12:18 PM Thread Starter
Sawed Off's Avatar
Originally Posted by joebob3093 View Post
hows the oil level?
The oil level is good, I just got it changed along with the fuel filter
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
Toyo AT's
post #6 of 10 (permalink) Old 10-30-2009, 12:50 PM
Super Moderator
John_G's Avatar
If it's fine cold and gets progressively worse as it gets hot, that's symptomatic of the cam sensor.
I vote for LIBERTY!
John_G is offline
post #7 of 10 (permalink) Old 10-30-2009, 07:45 PM
any codes?
brodiesau is offline
post #8 of 10 (permalink) Old 10-31-2009, 12:49 PM
biz
did you take advantage of the ford recall for your cam positioning sensor?
if not now would be a good time to try and get it to the dealer so its fixed for free.
2000 F-350 Super cab, Tadds tunes, AFE Pro Guard intake, 4" MBRP cool Duals, Nexus Gauges , Tubonetics Ball Bearing Turbo.
biz is offline
post #9 of 10 (permalink) Old 11-05-2009, 03:19 AM
Talking
my 96 powerstroke did the same thing and it was the cam shaft senser. once i fixed it no more troubles.
powerstroke96 is offline
post #10 of 10 (permalink) Old 03-22-2010, 01:25 AM Thread Starter
Sawed Off's Avatar
Yep, had it in again to the dealership it was a cam sensor. I found out another thing on my own though that I pointed out to the mechanic over at the ford garage. They have a rubber flap that was covering the intake hole. And what got me all the time was the filter minder kept on saying the thing was dirty. Well what was happening actually was the flap was getting sucked tight against the intake hole. I asked my service writer if this was right, after explaining to him why I thought it was incorrect. He said they would check it out. He ended up calling me and telling me that they folded that rubber piece out of the way and zip tied it. Sure has a little more scoot for some reason now lol. The truck is still a friggin pooch. couldnt tell you what the gears are. and I know the turbo is spooling correctly. I know for a fact, it dosent like to get up to speed very fast when pulling a goose neck trailer. thats for sure
2010 6.4 CC
The Diesel Garage
Can You Keep Up
MODS
recon lights
Toyo AT's
truck shutting off stroken97 1994-2003 7.3L Power Stroke 0 10-17-2009 05:52 PM
2004 cummins 5.9 shutting down bad??!! rumrunner439 5.9L Cummins (2003-2007.5) 12 01-05-2008 11:46 PM
Shutting off the wastegate 94straightpiped 5.9L Cummins 12 Valve (1994-1998.5) 3 10-16-2007 04:23 AM
shutting down problem slcdmax Duramax 2001-2004 (LB7) 3 03-14-2007 08:14 PM
Shutting Off bus driver Medium and Heavy Duty 0 03-05-2007 01:39 AM
