fuel regulator noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TSGS69400, this thread has received 3 replies and been viewed 923 times.
post #1 of 4 (permalink) Old 11-11-2009, 04:22 AM Thread Starter
git-r-done
TSGS69400's Avatar
Alrite I am on the brink of finishing my fuel system and I am presetting my aftermarket aeromotive regulator. I can hear it making a noise somewhat like a faucet running, is that normal? I have no prior experience with these.
Also is 50psi a good start? and what is the best pressure for a stock SD pump?
BTW I am running a 12 and a 5 micron filter, any comments/suggestions?
Thad Seybert
2008 F-350 crew cab short bed Lariat 4x4 6.4 with 3.73's Spartan flash update 250 210 175 150, S&B intake, MBRP cool duals, Rockford amps, Infinity speakers, Tuff Tonneau,
1996 F-250 extended cab short bed 4x4 7.3 5-spd with 3.55's , DIY STG 1's, 4" Diamond Eye duals, DIY Intake, dp tuner, Cobalt gauges, Adrenaline pump, SD springs, D66 turbo, 6.0 intercooler, Custom electric regulated fuel system, Truetrac.
TSGS69400 is offline
post #2 of 4 (permalink) Old 11-11-2009, 05:55 AM
pontiacross's Avatar
if there is still air in the system the regulator will be noisey.
I would run 55 to 60 psi with the stock pump.
I am running 70 with my aeromotive pump
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 4 (permalink) Old 11-12-2009, 04:04 PM Thread Starter
git-r-done
TSGS69400's Avatar
Alrite thanks for the advice. How about the filters? is 5 micron too fine of a filter?
Also can anybody find me a wiring diagram for the fuel pump on a superduty?
Thad Seybert
post #4 of 4 (permalink) Old 11-12-2009, 04:31 PM
Originally Posted by TSGS69400 View Post
...Also can anybody find me a wiring diagram for the fuel pump on a superduty?
There can't be much of a diagram since there are only two wires--key-on hot and ground.
jvencius is offline
6.0L Fuel regulator question S04X 2003-2007 6.0L Power Stroke 4 10-02-2009 03:43 PM
shimmed the fuel regulator... Fireguy 2003-2007 6.0L Power Stroke 28 04-19-2008 12:53 AM
OBS fuel regulator turtlecrawler Whats Been Sold 0 12-12-2007 06:15 AM
Testing Fuel Regulator hhrecovery The Parking Lot 2 08-04-2007 06:42 AM
bb fuel regulator mod bootcamp 2003-2007 6.0L Power Stroke 2 12-16-2006 02:25 AM
