Coolent? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Maverick26, this thread has received 5 replies and been viewed 1023 times.
post #1 of 6 (permalink) Old 11-13-2009, 06:56 PM Thread Starter
Coolent?
So all the other trucks I have been looking at have fell through, Im still on the search for the perfect tow rig. Im looking at a 1995 F350 with the 5 speed tonight. I know that the coolent is very important on the powerstrokes but I dont have a Ph tester and the guy didnt know anything about Ph and the coolent so im a little nervious. Should I be? Or can I just have it flushed and refilled and add the additive that is needed? Help!
Maverick26 is offline
post #2 of 6 (permalink) Old 11-13-2009, 07:45 PM
bushpilot's Avatar
just flush it <i hope its not 14 year old coolant>.
flush the coolant and INSTALL a coolant filter.
if you use green coolant buy a filter that contains SCA in
the filter (basically the additive is in the form of PELLETS that
desolve).
Filters that have SCA in them will help maintain the pH.
youll still need to occasionally TEST the coolant w/ a pH strip,
and youll have to change the filters (when the SCA desolves),
but changing a filter every 6 or 12 months is EASY and CHEAP.
coolant filtering can also extend the life of the water pump.
http://www.dieselsite.com/index.asp?...ROD&ProdID=443
Don R.
Truck Audio,
bushpilot is offline
post #3 of 6 (permalink) Old 11-13-2009, 07:52 PM Thread Starter
Ok sounds good, thanks for the good info. Ill do that if the rest of the truck checks out good. Is there anything else I should be looking for when buying a truck like this?
post #4 of 6 (permalink) Old 11-13-2009, 08:22 PM
bushpilot's Avatar
rust ? suspension wear ?
Don R.
Truck Audio,
post #5 of 6 (permalink) Old 11-13-2009, 08:27 PM Thread Starter
Ok cool, nothing tricky or weird with these older trucks then? Thanks for your help. Ill report it I get it or not.
post #6 of 6 (permalink) Old 11-13-2009, 09:01 PM
bushpilot's Avatar
others would be better to respond about issues w/ the OBS trucks.
Don R.
Truck Audio,
coolent probs. big peter 6.5L Diesel Engine 15 02-12-2009 02:41 AM
coolent leak imported_7inchstack 5.9L Cummins 12 Valve (1994-1998.5) 4 10-22-2007 04:48 AM
Evans Coolent blowin smoke Supporting Vendors Forum 1 03-29-2007 02:39 AM
Coolent leak Stacked6600 Duramax 2001-2004 (LB7) 8 02-12-2007 12:41 PM
