Bushing Help Please! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by BillsFan, this thread has received 20 replies and been viewed 3177 times.
post #1 of 21 (permalink) Old 12-13-2009, 08:47 PM Thread Starter
BillsFan's Avatar
Ok two things...
I am replacing my drop link / sway bar bushings. I took off the drop links but then got them messed up from side to side. Can someone look and tell me which one goes where. There is one that has a more pronounced bend than the other. Is that driver or passenger side?
Also, I rented a Bushing driver from AutoZone - How the hell do you use it? They didnt know and there are minimal instructions.
THANKS!!
(On a side note, shame on Ford for putting the passenger side drop link so close to the starter...)
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #2 of 21 (permalink) Old 12-14-2009, 07:02 PM Thread Starter
BillsFan's Avatar
Nevermind, I got it.
Ridin' Dirty #64
BillsFan is offline
post #3 of 21 (permalink) Old 12-16-2009, 03:05 PM Thread Starter
BillsFan's Avatar
Well, I got it all back together. Only issue I had was the top bolt on the passenger side drop link. I couldn't get it to go back in due to the starter housing on the block. So I flipped it around.
I found this helpful write up>
http://www.frontiernet.net/~jmray/F250Bushings.htm
Here's the finished product...
Ridin' Dirty #64
BillsFan is offline
The Following 2 Users Say Thank You to BillsFan For this addition to TDG:
double-s-diesel (12-16-2009), littlefred811 (07-28-2010)
post #4 of 21 (permalink) Old 12-16-2009, 10:01 PM
rock removal technition
ill be doin this soon to mine
double-s-diesel is offline
post #5 of 21 (permalink) Old 12-16-2009, 10:34 PM Thread Starter
BillsFan's Avatar
I took it for a long drive this afternoon on some crappy WV roads and its much improved. The front end seems tighter and it doesnt make that clunking sound when I hit dips, potholes or speed bumps. Worth the $45!
Ridin' Dirty #64
BillsFan is offline
post #6 of 21 (permalink) Old 12-16-2009, 11:47 PM
do you have a link to the parts that you used? Mine need done as well..
early '99 converted to late '99 F-350 dually, 4x4, 4 door, long bed, 6 speed. Midwest transmissions 05+ zf-6 transmission with their short throw shifter and SB clutch. Rosewood 180cc with 80% nozzles, Termy modded 17* HPOP, International bellowed up pipes, fs-2500, DP Tunes. A few other things here and there...
dually club member.. Why replace 5 tires when you can replace seven? I like my training wheels...
calebgriffin31 is offline
post #7 of 21 (permalink) Old 12-17-2009, 01:23 AM Thread Starter
BillsFan's Avatar
This is where I got mine...
http://www.energysuspension.com/
...or you can try the vendor section.
Ridin' Dirty #64
BillsFan is offline
The Following User Says Thank You to BillsFan For this addition to TDG:
calebgriffin31 (12-17-2009)
post #8 of 21 (permalink) Old 12-17-2009, 07:00 AM
Looks Great! How hard was it to get the old bushings out of the end links? Did you end up needing a press or something similar. I plan on doing this soon too.
99fordtruckguy is offline
post #9 of 21 (permalink) Old 12-17-2009, 01:49 PM Thread Starter
BillsFan's Avatar
I tried getting them out myself but it was impossible. I took them to a local machine shop and the guy pressed them out. Cost me $30.
Ridin' Dirty #64
BillsFan is offline
post #10 of 21 (permalink) Old 12-18-2009, 12:27 AM
brendonv's Avatar
Do the new ones have to get pressed in? Or do they slip in.
Do you have part #'s?
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
Spun cam bushing= Low Oil psi?? legend10 Medium and Heavy Duty 3 06-08-2009 11:06 PM
Bushing Kits? MILKINGCOWBOY 5.9L Cummins (1998.5-2002) 0 12-27-2007 02:27 AM
05 trac bar bushing EPDP99 General Ford Truck and Excursion 51 03-29-2007 04:46 AM
BB 3" bushing BigBadDodge Whats Been Sold 0 10-13-2006 03:53 AM
turbo bearing(bushing) chuggaluggin 1994-2003 7.3L Power Stroke 4 02-23-2006 02:44 AM
