Surging - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by davisa, this thread has received 6 replies and been viewed 2042 times.
post #1 of 7 (permalink) Old 12-15-2009, 01:00 PM Thread Starter
Surging
2001 7.3 Excursion, it seems like when I have been cruising down the highway a while and then pull off and come into a town it will "surge" or almost seem like it wants to cut out and then come back on. (sorry, best I can explain it). This only occurs when not towing. It never does it when towing a heavy load. It has an Edge stacked on a Superchips with the Edge set on "3".
Can anyone lead me down a path on this? Thanks.
2001 Excursion 7.3, Superchip(now removed), Edge, Home made air intake.
2008 GMC 3500 Crew, Dually, 6.6 Duramax - Stock
davisa is offline
post #2 of 7 (permalink) Old 12-15-2009, 09:20 PM
BillsFan's Avatar
Mine has done something similar to this on two occasions. Both times it was the gas pedal assembly. About $125 from Ford and 20 minutes to change out.
and Bob @ DieselSite!
TDG Singles Club Member #73
Ridin' Dirty #64
BillsFan is offline
post #3 of 7 (permalink) Old 12-16-2009, 01:39 PM
The one and only
Take the stacked chips off and see what happens. You can not stack chips on a PSD is just dont work that way. Your Superchips is programing your PCM and telling it one thing and then your Edge is plugged into censers around the truck telling it another. Bad idea
Take them both off and see if it still does it.
Do your self a favor and sell both of them and get a custom tuned chip. Your truck will love you a lot more.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #4 of 7 (permalink) Old 12-18-2009, 01:24 PM Thread Starter
Thanks for the replies. I will try it without the Superchip and see what happens before I try it without both.
davisa is offline
post #5 of 7 (permalink) Old 02-16-2010, 07:26 PM Thread Starter
As a follow-up:
I took the Superchips program out of it and have been running it with just the Edge. Mostly trying Levels 2, 3 and 4 (5 is highest). I have not had the surging since, however it definetly does not run as strong as it did before. Although I don't want to do damage to it by running them both if that's the case. Now when I get on it, even moderately, it throws a P01211 "ICP Not Controllable - Pressure Above/Below Desired".
It will still run the same even if the SES light is on. Not sure which direction I will go from here.
Thanks for the help.
davisa is offline
post #6 of 7 (permalink) Old 02-16-2010, 07:29 PM
The one and only
ditch the edge.. the code is from piss poor tuning.
Like I had said b4... Get a good custom tuned chip and it will not happen.
Dyno Sheet
post #7 of 7 (permalink) Old 02-17-2010, 01:20 AM
Big Stroker PSD's Avatar
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
Surging?? Chuck488 2003-2007 6.0L Power Stroke 6 08-21-2009 07:19 PM
5.7L TPI surging 4rcFed General Gas Vehicle 2 07-14-2009 06:06 AM
Engine surging at 9 mph JLWelding Introductions 4 04-22-2008 08:23 AM
Surging firehillbilly Duramax 2006-2007(LBZ & LLY) 4 12-22-2007 02:01 AM
SCT before surging 6L strokin 2003-2007 6.0 Tuner Forum 4 03-02-2007 03:27 PM
