O/D light not illuminating, and O/D not turning off - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by charlestrm, this thread has received 2 replies and been viewed 949 times.
post #1 of 3 (permalink) Old 01-13-2010, 02:36 PM Thread Starter
Send a message via AIM to charlestrm
On my 2001 7.3 CC Dually my overdrive light on the gear selector will not illuminate in gear. It does illuminate when in park however. Also while in gear it does not down shift (turn off overdrive) any help with this problem would be much appreciated! :dunno:
charlestrm is offline
The Following User Says Thank You to charlestrm For this addition to TDG:
Pwner (01-13-2010)
post #2 of 3 (permalink) Old 01-13-2010, 05:19 PM
The O/D wire on the shift column can get pinched from time to time. Probably why it works in park, but not when you have the gear selector in another position.
Pocket is offline
post #3 of 3 (permalink) Old 01-13-2010, 08:08 PM
Picture for the wires to look for
Hi,
Thanks for the post.
There are two wires that are revealed once the shroud is removed on the sterring column.
Both of mine were sliced clean through.
I little solder, shrink wrap (if you have it) and it's good to go.
Sorry, no picture.. although I do have some. I just don't have anywhere on the web to place them to link to here.
message me your email address and I will be happy to provide.
Pwner is offline
Voltage light turning on and off? Torched 2003-2007 6.0L Power Stroke 14 02-06-2012 12:44 AM
tow haul light flashing trans temp pegging andcheck guage light comes on powermad 2003-2007 6.0L Power Stroke 12 05-17-2010 12:34 AM
More to turning up an ip? 710_burner 7.3L and 6.9 IDI (Pre 1994) 17 11-18-2007 06:53 PM
Door Ajar light wont go off nor will the dome light?? imported_99powerstroke 1994-2003 7.3L Power Stroke 10 03-14-2007 05:13 AM
Turning up F-800 ACC inc. Medium and Heavy Duty 5 01-22-2007 07:32 AM
