intermitent grind and pop in the front end - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ccp, this thread has received 10 replies and been viewed 1444 times.
post #1 of 11 (permalink) Old 01-18-2010, 05:47 AM Thread Starter
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
im having an intermitent grind and pop in the front end of my 99.5 F-250 it only does it every now and then and never when under power only does it when coasting or braking, it almost sounds like its on the front drivers side or passanger side or one side or the other like its kicking back and forth between wheels but only one at a time we pulled the drivers side wheel off today and the caliper pads looked good and in place. it just started doing it recently and me and my buddies are at a complete loss for whats happening.
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
post #2 of 11 (permalink) Old 01-18-2010, 06:01 AM
Could be a couple of things.... bad 4x4 hub, bad wheel bearings, etc.
Pocket is offline
post #3 of 11 (permalink) Old 01-18-2010, 07:16 AM Thread Starter
ccp
ccp's Avatar
yea we thought about all those things but i dont think its the hub it really doesnt sound like a hub or bearing. the more i think about it it might be something to do with that dust shroud on the rotors, but im not ruling anything out. i guess ill have to tear down the pass. side later today and try to figure something out. if anyone else has anything i should look for or check or might have had anything like this happen any more advice would be great.
custom intake
dp tuner
ccp is offline
post #4 of 11 (permalink) Old 01-18-2010, 05:06 PM
Mod Friendly Title
Zaairman's Avatar
Does it sound like a tire rubbing? If so, I'm betting inner wheel bearing for $500, Trebek. It's a $30 fix and will take you an hour to replace both sides.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #5 of 11 (permalink) Old 01-18-2010, 10:44 PM Thread Starter
ccp
ccp's Avatar
yea the more i think about it, you might be right about the bearing it has been wet around here and bearings dont like wet at all.
custom intake
dp tuner
ccp is offline
post #6 of 11 (permalink) Old 01-19-2010, 12:51 AM Thread Starter
ccp
ccp's Avatar
could anyone tell me where i might locate the inner wheel bearing and is it seperate from the part that bolts to the axle with studs? or a brief description of what i need to do to change the inner wheel bearing? but im wondering why if it were a bearing wouldnt it grind all the time? it only does it every now and then.
custom intake
dp tuner
ccp is offline
post #7 of 11 (permalink) Old 01-19-2010, 01:15 AM
TDG Mafia #95
bluovaltruk01's Avatar
The axle shaft bearing is a torrington style bearing. Timken makes them, and their part number is B2110. Autozone sells it, part number B2110. If you can get it to make the noise again, put it into 4wd while its doing it and see if it goes away. If it does, that's most likely your problem.
If you buy the whole wheel hub assembly, one of these bearings is installed already. Ford will say that if the inner axle bearing goes out, you have to replace the entire wheel hub assembly. If you do, you'll spend around 400 bucks per side, instead of about 15, just for parts. This bearing does need to be pressed in. Anyone with a bottle jack press can do this pretty easily. Hope this helps
bluovaltruk01 is offline
The Following User Says Thank You to bluovaltruk01 For this addition to TDG:
ccp (01-19-2010)
post #8 of 11 (permalink) Old 01-19-2010, 01:57 AM Thread Starter
ccp
ccp's Avatar
its almost like something is hanging up rather than gone bad it does it a few times on the way to the gas station 2 miles or so and it really sounds like thin metal hanging up on something spinning but we cant see anything hanging up.
custom intake
dp tuner
ccp is offline
post #9 of 11 (permalink) Old 01-19-2010, 03:19 AM
Big Stroker PSD's Avatar
could it be a sticky caliper pin ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #10 of 11 (permalink) Old 01-19-2010, 04:03 AM
Mod Friendly Title
Zaairman's Avatar
Ford actually sells the inner bearings... its where I bought mine from. When I gave my parts guy the part #, he immediately knew what I was doing.
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
Tranny Grind... pblankenship Medium and Heavy Duty 15 04-04-2012 01:21 PM
3rd gear grind? Plufis 2003-2007 6.0L Power Stroke 3 12-09-2009 04:42 PM
Intermitent cutoff AaronS 1994-2003 7.3L Power Stroke 11 04-22-2007 04:15 PM
The Daily Grind!!!! 05PSD 2003-2007 6.0L Power Stroke 5 03-03-2007 01:19 AM
Back to the grind rickou812 2003-2007 6.0L Power Stroke 20 02-11-2006 06:24 PM
