big oil? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by haulin99, this thread has received 8 replies and been viewed 1436 times.
post #1 of 9 (permalink) Old 01-26-2010, 04:12 AM Thread Starter
haulin99's Avatar
big oil?
i am looking at a gen III style big oil setup and was wondering how relieable it would be on a dd rig or what porblems might arise on a dd. it will see some long trips and very little but heavy towing. plz and thanks for any and all info.
haulin99 is offline
post #2 of 9 (permalink) Old 01-26-2010, 01:22 PM
The one and only
Why a gen III?
What injectors are you going with?
If it is anything less then a 250cc 200% hybrid I would say an Adrenaline would work just fine at half the money.
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #3 of 9 (permalink) Old 01-26-2010, 03:50 PM Thread Starter
haulin99's Avatar
i found a homemade style gen III big oil setup for about the same price as an adrenaline.
as for the injectors i havent made my mind up yet so here is what im looking at,
BI code injectors.(will be moded)
diy 238\100 hybirds.
300\200 hybirds.
i have changed my mine on this since i started so many times, idk why, geuss i just want to get it right on the first try this time. as mentioned above any and all info is greatly apperciated!!
haulin99 is offline
post #4 of 9 (permalink) Old 01-27-2010, 03:28 AM
CSIPSD's Avatar
Home made... Sounds scary...
Who knows with a DD set up.
CSIPSD is offline
post #5 of 9 (permalink) Old 01-27-2010, 05:04 AM Thread Starter
haulin99's Avatar
came across some BD codes today.
hmm........
haulin99 is offline
post #6 of 9 (permalink) Old 01-27-2010, 05:49 AM
CSIPSD's Avatar
Hybrids, Overdrive and move on... Its not rocket science...
CSIPSD is offline
post #7 of 9 (permalink) Old 01-28-2010, 12:02 AM
Big Stroker PSD's Avatar
Excuse my ignorance , but what is a dd setup ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #8 of 9 (permalink) Old 01-28-2010, 02:03 AM
CSIPSD's Avatar
DD... Daily Driver...
CSIPSD is offline
The Following User Says Thank You to CSIPSD For this addition to TDG:
Big Stroker PSD (01-28-2010)
post #9 of 9 (permalink) Old 01-28-2010, 06:15 AM Thread Starter
haulin99's Avatar
haulin99 is offline
