mysterious oil leak - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by rjs35510, this thread has received 7 replies and been viewed 1196 times.
post #1 of 8 (permalink) Old 01-27-2010, 02:36 AM Thread Starter
mysterious oil leak
my 01 250 with 215000 on it just started leaking oil between the motor and trans and around the starter. just curious it is a standard and my clutch is not slipping what kind of oil leaks do these trucks get back there. could it be a rear main and how hard is that to fix or is it a valve cover. truck has never leaked oil . thanks robert
rjs35510 is offline
post #2 of 8 (permalink) Old 01-27-2010, 03:01 AM
Big Stroker PSD's Avatar
Probably the o'rings under the turbo . It will run down and look like the main is leaking . 6 bucks at Ford for the o'rings .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #3 of 8 (permalink) Old 01-27-2010, 03:25 AM
CSIPSD's Avatar
Look in the valley and see if there is any oil down there, then check the turbo pedistal. More then likely it is the turbo O rings or the EBPV rod...
CSIPSD is offline
post #4 of 8 (permalink) Old 01-27-2010, 01:35 PM
Yea, take a look in the valley on top of the engine. If there is oil in there, wash it out, then take another look to see if you can see where its coming from. If the valley in the front does'nt fill up again it is most likely turbo pedistal o rings. If the valley is full up to the front, it may be coming from the HPOP plugs or gasket and running back.
Also, go ahead and check the clamps on the intercooler boots. Mine were a little loose and oil in time weeped out and while it did not leak down the valley drain hole, it did leave residue in the valley.
Do a search on the HPOP non serviceable plug and see if that could also be a culprit.
2002 F-250 Crew 4x4
Tuner: Yes
Transmission: Yes
Exhaust: Yes
Intake: Yes
Injectors: Yes
Other Stuff: Yes
NotMyFirstBBQ is offline
post #5 of 8 (permalink) Old 01-27-2010, 11:58 PM
Be sure its oil and not diesel . After the diesel slops around in the valley it gets dirty and black .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #6 of 8 (permalink) Old 01-28-2010, 12:57 AM Thread Starter
checked the turbo o rings and the hpop lines but no oil there.went under the truck and could see that the passenger valve cover had a little excess oil on it than usual? its like its all over the oilpan, head and valve cover but not leaving oil on the ground. could it be pushing oil out of the oil fill tube while driving or what???? thanks for the replys and i keep looking for it.
rjs35510 is offline
post #7 of 8 (permalink) Old 01-28-2010, 04:16 AM
valve cover gasket ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #8 of 8 (permalink) Old 01-28-2010, 09:37 PM
The fill spout could be leaking slightly. There is a gasket-oring under it. It turns a half turn or so and locks in like the old style oil caps used to. Wipe it off, then watch it. How careful are you when you add oil> I get a little squirley when I don't have a funnel and end up spilling it down the tube.
I would use some simple green and try to clean the area, then see where it comes back..
Maybe you could even retorque the valve cover gaskets...
2002 F-250 Crew 4x4
Tuner: Yes
Transmission: Yes
Exhaust: Yes
Intake: Yes
Injectors: Yes
Other Stuff: Yes
Mysterious Leak? MaineHD 2008-2010 6.4L Power Stroke 2 01-07-2010 06:11 AM
Mysterious Fuel Leak tattoo6.0 2003-2007 6.0L Power Stroke 3 07-28-2009 05:55 AM
Mysterious Sound gr33ng0bl1n 2003-2007 6.0L Power Stroke 2 07-17-2009 02:35 AM
OBS Mysterious Oil Leak 75stroppe 1994-2003 7.3L Power Stroke 3 06-26-2007 10:26 PM
Mysterious hpop check valve Diesel Dog 1994-2003 7.3L Power Stroke 7 05-02-2007 12:52 AM
