psd idles good but won't run out on top end - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by wreckit59, this thread has received 41 replies and been viewed 4078 times.
post #1 of 42 (permalink) Old 02-07-2010, 05:07 PM Thread Starter
Unhappy psd idles good but won't run out on top end
i have a 2000 psd 6 speed that will idle all day long but when i go to drive it after about a mile or so it will act like it is loading up if you stomp on it it may die or it may backfire and blow out a lot of smoke then try and run till you shift the next gear it seems to do it worse around 2200 rpms. we have changed the map sensor cps fuel pump and filter oil was changed around 750 miles ago please help this is my work truck and i need it running.
wreckit59 is offline
post #2 of 42 (permalink) Old 02-07-2010, 05:08 PM Thread Starter
it also has a download on it not sure which one but the previous owner said he put one on it
post #3 of 42 (permalink) Old 02-07-2010, 05:15 PM
Big Stroker PSD's Avatar
have you tried to pull codes ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
The Following User Says Thank You to Big Stroker PSD For this addition to TDG:
wreckit59 (02-07-2010)
post #4 of 42 (permalink) Old 02-07-2010, 05:17 PM
SmokeCloud's Avatar
Real Trucks Burn Diesel!
SmokeCloud is offline
The Following User Says Thank You to SmokeCloud For this addition to TDG:
post #5 of 42 (permalink) Old 02-07-2010, 05:51 PM Thread Starter
the only thing i have is an edge programmer but it reads code 1211 inj. presssure high or low thanks for any help you guys can give
post #6 of 42 (permalink) Old 02-07-2010, 06:05 PM
P1211 ICP Not Controllable - Pressure Abow/Below Desired
Might be the ICP
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #7 of 42 (permalink) Old 02-07-2010, 06:16 PM Thread Starter
where is the icp located i have a 2001 psd sitting right beside this one that runs i can change parts back and forth
post #8 of 42 (permalink) Old 02-07-2010, 06:19 PM Thread Starter
i cleaned the ipr and reinstalled it but no change
im lost
post #9 of 42 (permalink) Old 02-07-2010, 06:59 PM
Hope this helps
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #10 of 42 (permalink) Old 02-07-2010, 07:42 PM
ccp
THE MASTER OF DISASTER
ccp's Avatar
Send a message via AIM to ccp
i would like to throw my hat in the ring and say its the under valve cover harness. have it buzz tested if you havent done so yet, when my uvch went it idled fine but ran like crap at higher rpms
99.5 F-250 7.3 4X4 reg cab.
custom intake
dp tuner
suncoast/DTT Frankentrans
and a whole bunch of other crap i dont really need.
www.cabincreekpaintball.com
ccp is offline
The Following User Says Thank You to ccp For this addition to TDG:
Idles too high in gear White Beast 5.9L Cummins (2003-2007.5) 20 12-16-2011 06:07 PM
can anyone make a tune that idles like the vgt is unplugged??? morepower02 2003-2007 6.0 Tuner Forum 12 03-22-2009 10:30 PM
Truck idles good then just shuts off 7.3stroker281 1994-2003 7.3L Power Stroke 8 01-31-2008 02:54 PM
drive wont idles right spanky 5.9L Cummins (1998.5-2002) 6 09-21-2007 08:41 PM
Long Idles gobigorgohome 2003-2007 6.0L Power Stroke 10 01-24-2007 09:51 AM
