2001 7.3 hesitation in reverse - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tec101, this thread has received 8 replies and been viewed 3155 times.
post #1 of 9 (permalink) Old 02-09-2010, 07:50 PM Thread Starter
My 2001 7.3 has started hesitating in reverse only doesnt feel like slipping it will not accelerate as if it was lacking fuel but in drive or park it will take its fuel as normal any suggestions
tec101 is offline
post #2 of 9 (permalink) Old 02-11-2010, 03:40 AM
TDG Mafia
Jeffybuilt's Avatar
My plow truck is doing the same thing! Its like it won't fuel for a second and has, as us Dodge guys say "dead pedal." But its only in reverse....I'll be watching this thread to see what comes up, as I'm not too keen on these 7.3's.
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #3 of 9 (permalink) Old 02-11-2010, 04:01 AM
plainredtruck's Avatar
Images: 11
Could be fuel pump.
Could be Throttle Position Sensor (accel pedal).
Could be plugged fuel filter(s).
What have (either/both) of you checked?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #4 of 9 (permalink) Old 02-11-2010, 12:32 PM Thread Starter
Bolth good suggestions but the acceleration is fine in any other gear but reverse witch should eleminate both of them they should cause the problem in any gear. IM going to change the fuel filter and if it helps Ill let you know.
tec101 is offline
post #5 of 9 (permalink) Old 02-12-2010, 12:51 AM
Big Stroker PSD's Avatar
I have the same problem in my work truck. I think its more of a tranny problem than filters . Hope we can solve the problem It has been driving me nuts for awhile.
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #6 of 9 (permalink) Old 02-12-2010, 02:21 PM
Send a message via AIM to flatbed
I've had a7.3 F-350 4wd auto trans for a few moths , mostly ironing out problems on this plow truck (68000 mi)
the truck when shifted into reverse would hesitate , lower rpms and a couple of times stall out. took it to a trans mission shop ( know reputation) they changed fluid , filter in trans and transfer case and two lines ,the lines probably due to salt deterioration.
$423.29 ........problem gone
flatbed is offline
post #7 of 9 (permalink) Old 02-12-2010, 05:06 PM Thread Starter
Got mine repaired I hooked up to gennis 2 and found that while in reverse the diginal trans sensor was showing overdrive and then reverse while in reverse I chanaged the sensor and cleaned the plug currosin and problem gone. Hope this helps someone else with this problem. And all through checking there never were no trouble codes. Total cost of repair was $45.00 for a new switch.
tec101 is offline
post #8 of 9 (permalink) Old 02-12-2010, 11:53 PM
thanks for the info guys !
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #9 of 9 (permalink) Old 02-14-2010, 10:28 PM
Diesel Kid
mine was doing the same thing and i replaced the fbr spring and it quit so idk if the spring was just wore out or something
2002 f-250 4x4 - its got a little done to it
Riding Dirty club #56
Originally Posted by Slick Willie View Post
Dang redneck and his zipties.
CATman08 is offline
Low voltage ...Hesitation? Super 05 2003-2007 6.0L Power Stroke 14 04-12-2009 08:48 PM
Hesitation problems cjwoz Duramax 2001-2004 (LB7) 0 02-11-2009 05:44 PM
Hesitation at WOT powerstroken160 Duramax 2001-2004 (LB7) 6 01-22-2009 12:39 AM
hesitation at the trottle? robertf610 2003-2007 6.0L Power Stroke 1 07-01-2007 02:38 AM
6.5 hesitation and stalling plowking 6.5L Diesel Engine 8 11-10-2006 06:09 AM
