truck wont go into gear - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by swaggs321, this thread has received 7 replies and been viewed 1198 times.
post #1 of 8 (permalink) Old 02-10-2010, 01:55 PM Thread Starter
i have a 2002 ford f250 with a six speed manual, i have a south bend clutch. i was driving the other day and it started going into gear hard. the only way i can get it into rev or first is to shut the truck off. i have replaced the clutch master cylinder and slave cylinder any help would be great it my only transportation as of now waiting on insurance money from wrecking my car thanks sam
swaggs321 is offline
post #2 of 8 (permalink) Old 02-10-2010, 02:12 PM
The one and only
Did you bleed the master salve cylinder's right? or did you get a pre bled kit.
Also could be a broken clutch fork
1999.5 Ford F-250 7.3l 4x4 PSD DI Short block, Ported Heads, Head studs, Over size valve springs, DI Push Rods, DI RR, GTP38R, GSL 392 fuel pump with 3/8 line feeding 238cc Injectors from Nate @ Unlimited Diesel and Tuning from Matt @ Gearhead Automotive
Auto to ZF6 Completed
520hp and 926tq - 5/23/09
Dyno Sheet
big_stroker is offline
post #3 of 8 (permalink) Old 02-10-2010, 02:41 PM Thread Starter
i have bleed the system about three times its like the clutch is not pressing on the shift fork far enough i was going to try and bleed it again today. and also when i put the truck in gear and start it up it will start to creep forward like the clutch is dragging a little bit. is it common for the shift fork to bend or crack and cause this problem?
post #4 of 8 (permalink) Old 02-10-2010, 02:47 PM
The one and only
You might want to just go to ford and get a new pre-bleed system. Bleeding them systems can be a PITA
Dyno Sheet
post #5 of 8 (permalink) Old 02-10-2010, 03:06 PM Thread Starter
yea i might just suck i already spent the money on the others and they are metal instead of plastic thats why i went that route instead
post #6 of 8 (permalink) Old 02-10-2010, 04:40 PM
brendonv's Avatar
Try bench bleeding it. I usually use a piece of old brake line with the right size nipple on the end to screw into the MC. Fill with fluid, redirect the hose back into the reservoir, and use a screw driver as the rod to pump it.
Early 1999 F350 DRW Dump, 6spd 4x4, 4" Turbo Back and DIY Intake
Early 1999 F350 SRW 8' Box, 6spd 4x4 Stock
brendonv is offline
post #7 of 8 (permalink) Old 02-11-2010, 04:39 PM Thread Starter
brendonv are you talking about the brake master cylinder or clutch master cylinder? but i did bleed it again last night it seems to be getting better the more i drive it, just going to keep my fingers crossed for now the rest of the air works out. thanks for every ones help
post #8 of 8 (permalink) Old 02-11-2010, 10:50 PM
brendonv's Avatar
Clutch, that's what the threads about right?
I've done it on all my vehicles on the past I've changed the master in, and never had a air problem.
brendonv is offline
my truck wont run and i need some help.... biz 1994-2003 7.3L Power Stroke 11 10-24-2009 08:58 PM
Please Welcome 8 Lug Truck Gear! fordt Site Information 14 09-13-2009 05:31 AM
Truck wont run SAK 2008-2010 6.4L Power Stroke 7 02-20-2008 04:00 PM
Help, truck wont start morepower02 2003-2007 6.0L Power Stroke 21 12-12-2005 04:57 AM
