O/D Off Button = Kill Switch - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by davisa, this thread has received 3 replies and been viewed 1411 times.
post #1 of 4 (permalink) Old 02-16-2010, 08:05 PM Thread Starter
Had a strange one last night. Was coming down a long grade in the snow and had the O/D off. When I got to a point where I could roll a little, I pushed the button to turn the O/D back on again and it instantly killed the motor. I drifted to a place I could stop, turned everything off and it started but it took 3 times to start it. I could not get it to do it again and I must have cycled that button 25 more times. Any help on this one would be appreciated.
Thanks.
2001 Excursion 7.3, Superchip(now removed), Edge, Home made air intake.
2008 GMC 3500 Crew, Dually, 6.6 Duramax - Stock
davisa is offline
post #2 of 4 (permalink) Old 02-19-2010, 06:58 AM
MAFIA MEMBER 106
camojeeper's Avatar
Bad ipr orings can cause staling will it doit coming down to a stop?
STEVE TDG MAFIA#106
camojeeper is offline
post #3 of 4 (permalink) Old 02-19-2010, 12:40 PM Thread Starter
It has never stalled on me in any other situation. The only symptom close to this is I noticed in trying to duplicate the situation with the O/D switch, when I put the O/D back on the rpm's drop to about 500. I can't say if it was always that way because I didn't pay attention to it before the problem.
Thanks.
davisa is offline
post #4 of 4 (permalink) Old 02-20-2010, 07:11 PM
HalfAst Racing
skippy's Avatar
Images: 1
ive seen the od harness chafe and short on the column where it comes out of the shifter.it usually just blows the fuse though.you may have a trans issue the way it sounds.
2004 f250 cc/sb,magnaflow turbo back.rockin rcd tunes 18" harley wheels
2001 excursion 6in 35s
1993 mustang lx,6.0l 5r,project rattlesnake
skippy is offline
Kill switch suggestions lithgow 1994-2003 7.3L Power Stroke 15 08-04-2010 12:52 PM
code read kill switch? turboftw 1994-2003 7.3L Power Stroke 13 03-31-2009 02:31 AM
Well I put the #25 fuel button in. chris142 Medium and Heavy Duty 18 06-07-2007 04:37 AM
kill switch lubeowner Sled Pulling 2 02-01-2007 03:40 AM
Kill switch, How To's bigbirdF250 2003-2007 6.0L Power Stroke 12 11-22-2006 07:24 PM
