no start problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by gvolp69, this thread has received 6 replies and been viewed 1377 times.
post #1 of 7 (permalink) Old 02-21-2010, 02:40 AM Thread Starter
no start problem
I have a '97 f250 that won't start. a few months ago when it was really cold the truck wouldn't start. the check engine light would come on when i started to crank the engine and no fire. well today i went out to try to start the truck and it fired off and ran for a few seconds. so i tried again and it ran for about two minutes and then quit again. so i replaced the cam sensor and it still won' fire. and the check engine light still comes on. i have all of the dash lights and warning bell. what else should i check. i don't have a way of checking for codes. thanks in advance for the help!!!
gvolp69 is offline
post #2 of 7 (permalink) Old 02-21-2010, 03:47 AM
pontiacross's Avatar
pull the fuel filter and make sure the bowl is full. Did it just shut off or sputter out and dye?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 7 (permalink) Old 02-21-2010, 05:02 AM
TDG MAFIA #101
tm0231009's Avatar
Sounds like it's not getting the fuel it needs...
On the hunt for a 7.3 preferably CC or Ext. Cab SB...Let me know of any deals.
1979 Ford F-100 Ranger, Custom dark purple and silver paint, 15"x8"117 Series Eagle Alloy's, Winston tires, 400 cu - Work In Progress!! http://www.cardomain.com/ride/2570291
"The only dumb question is the one not asked."
TDG MAFIA MEMBER #101
TDG SINGLES CLUB MEMBER #88
tm0231009 is offline
post #4 of 7 (permalink) Old 02-21-2010, 12:00 PM Thread Starter
it just died. no sputtering like it was running out of fuel. that is what has me baffled. i will check the bowl today.
gvolp69 is offline
post #5 of 7 (permalink) Old 02-21-2010, 03:32 PM
My '97 did that last year. Lost story short. The fuel heater element in the water separator(area) in the top center of the engine can rust, then short out. 30 amp fuse, and not nearly as difficult to replace as the large check I wrote to have it towed and a (very) good mechanic fix it.
Sorry about the lousy description, not enough coffee yet.
littlefred811 is offline
post #6 of 7 (permalink) Old 02-21-2010, 04:08 PM
Big Stroker PSD's Avatar
IIRC doesnt that fuse run the PCM too, if it was blown it wouldn't run at all right ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #7 of 7 (permalink) Old 02-21-2010, 09:54 PM Thread Starter
checked the fuel bowl and found out that it was empty. filled with fuel and added anti-gel to the tanks and it fired off and ran. so i got it out of the snow bank and ran it for a while. thanks for the great help!!!
gvolp69 is offline
Won't start problem stillcummin 5.9L Cummins (2003-2007.5) 2 09-22-2009 12:10 AM
start up problem powerstroke03 2003-2007 6.0L Power Stroke 4 02-06-2007 12:26 AM
ISC No Start When Hot Problem Birken Vogt Medium and Heavy Duty 1 01-13-2007 01:23 AM
cold start problem tinker1mn 1994-2003 7.3L Power Stroke 5 12-20-2006 04:16 AM
new to this cold start problem fleedog 2003-2007 6.0L Power Stroke 9 11-25-2006 05:42 AM
