PLEASE HELP front brakes removal - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by just visiting, this thread has received 12 replies and been viewed 1821 times.
post #1 of 13 (permalink) Old 02-21-2010, 08:50 PM Thread Starter
hey guys 1997 f-250 4x4 here I have no idea how to remove the brake rotors, i cant get the hub offi have removed the auto hub cap, the snap ring and everything all the way to the 3 thrust washers and the half ring with the tab on it, I have no idea where to go from here, i rented a hub nut socket set but there is nothing that they fit, Please help i am lost, i am down a vehicle and have somewhere to be soon, and never had a vehicle that was set up this way.
2007 Dodge Ram 2500 lonestar 5.9 CRD, 6-Speed
full MBRP 5" turboback, S&B intake, FASS, ISSPRO gages, BD Diesel steering stabilizer, Tough country leveling kit, Air lift Rear leveling, Southbend clutch, XD Hoss 18" wheels, Nitto Trail grapplers, Satellite radio, LED tailights
1997 ford f-250 POWERSTROKIN auto ex cab LB, homemade intake, superchips programmer, trans, egt, boost gages, tripple a pillar pod (daily driver)
2005 dodge SRT-4 2.4turbo ED hard pipes, aem short ram, MPx 3" turboback, HKS SSQ BOV, AEM wideband, Motegi Mr7 18"rims custom painted (weekend racer) [email protected] 107
2001 suzuki GSX-R600 K&N, Two bros. exhaust, neons, polished frame, (sumertime DD, and track toy)
11.000 @ 127
2006 raptor 700R blue dirt toy
2006 raptor 700R white dirt toy
just visiting is offline
post #2 of 13 (permalink) Old 02-21-2010, 10:01 PM
Big Stroker PSD's Avatar
I think there is one more nut to remove , it should be holding the bearing on .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #3 of 13 (permalink) Old 02-21-2010, 10:11 PM Thread Starter
i give up, i have not removed any nuts just E clips and such, i do not see a nut in there anywhere, i am going to most likely take it to tire discounters to do it i need this truck and just dont have the time to work on it
11.000 @ 127
post #4 of 13 (permalink) Old 02-22-2010, 01:08 AM Thread Starter
I have picks of ow far i got if anyone thinks they will help but i would have to email them to you or text them there on my BB and i dont have a current photobucket account
11.000 @ 127
post #5 of 13 (permalink) Old 02-22-2010, 02:33 AM
When I did mine (01) I needed a BFH and that was it... they so stick like mad... (use a rubber mallet...)
2001 Extended Cab F250 4x4, Long Bed, Automatic, ATS Housing, Edge Juice with Attitude, Edge Evolution, Ford AIS, 4" Pro-Flo Exhaust, ISSPro 3 Gauge kit from Dieselmanor, Warn Manual Hub Locks
tpcrouch is offline
post #6 of 13 (permalink) Old 02-22-2010, 02:59 AM
I think you can attach the pics to your post .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #7 of 13 (permalink) Old 02-22-2010, 04:54 PM Thread Starter
well i was reading around on here and found nothing, but the diesel stop had a post on it and it says the manul ubs use the tools that have the tabs on them, the auto hubs use a thin walled 2-3/4 spindle socket so i am going to go to KOI and see if they have one if not i will do the 35 min drive to NAPA, and pick it up there, Im going to give it one more attempt before i take it to the tire shop. this is my last day off work and then I start on a 72 hr shift so i really need to get it done. My wheel is already turning orange and i am afraid that has destroyed a wheel. I hope not.
11.000 @ 127
post #8 of 13 (permalink) Old 02-22-2010, 05:09 PM
Dude... I just took mine off this morning (sticking caliper slide)... there is nothing to remove to get that rotor off once the caliper has been moved. Smack it with a freakin hammer. (preferably a mallet... go back and forth hitting it top and bottom and it will eventually break loose).
tpcrouch is offline
post #9 of 13 (permalink) Old 02-22-2010, 05:38 PM
Resident GINGER
CFRO's Avatar
Send a message via MSN to CFRO
IF you do have to go to Napa, or a parts store, check out a Chilton or some other brand manual. It could be worth the $15.
08 Ranger Grabber Orange. XLT 4x4 5 Speed Manual Super cab. Sirius. Silvana 9007 and 9415's. Amsoil 0w30 (Mileage Maximizer). Dee Zee Powder Coated Tool Box (PEELING). Dual 3' Fire Sticks. Cobra 75 X.
94 F-350 CC LB 5 -Speed. 4.10's. MBRP. Single Mass. 265/75's on 16x8's. Uniden CB. 3' Firestick.
Single club # 61
CFRO is offline
post #10 of 13 (permalink) Old 02-22-2010, 11:18 PM
The hubs are not the same on his obs . Your SD has a wheel bearing hub assembly
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
International S 1954 front brakes?? 99busa Medium and Heavy Duty 2 11-06-2009 05:29 AM
Front Brakes boobin 2003-2007 6.0L Power Stroke 5 10-05-2009 02:08 AM
Front Brakes 2wd = Ooch $$$ NotMine 2003-2007 6.0L Power Stroke 7 08-25-2009 01:21 AM
Front suspension and brakes on HD pickups FireHunter General GM Truck Forum 1 02-13-2008 01:35 AM
need front brakes powerstrokeit Supporting Vendors Forum 1 11-06-2007 03:13 AM
