400hp - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by stroke this, this thread has received 11 replies and been viewed 4841 times.
post #1 of 12 (permalink) Old 03-09-2010, 01:05 AM Thread Starter
400hp
what do i need to do to get 400hp out of a 97 f250
06 4dr f-350 lariat with 8.5in lift 20x14 welds 37in tires, sct with dj's tune straight pipe recon lights, HIDs
stroke this is offline
post #2 of 12 (permalink) Old 03-09-2010, 02:23 AM
pontiacross's Avatar
intake, exhaust, custom chip, stage 2 injectors, and a 17degree HPOP (out of 99.5 + 7.3) should get you real close.
add a domminator 66 turbo and maybe a fuel system and it shouldl be easily over that mark, and a lot of fun to drive
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 12 (permalink) Old 03-09-2010, 02:57 AM
what 17degree HPOP mean? like 17 degree advance or retarded what
cong is offline
post #4 of 12 (permalink) Old 03-09-2010, 03:20 AM
high pressure oil pumps are a fixed displacement piston pump, 17 degree refers to the swashplate angle inside the pump. the more angle the more they flow.
the 94 to early 99 trucks all had 15 degree pumps.
Ross
Tow Rig
post #5 of 12 (permalink) Old 03-09-2010, 05:34 AM
Mod Friendly Title
Zaairman's Avatar
About $6000
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #6 of 12 (permalink) Old 03-09-2010, 09:02 AM
easy money's Avatar
Im right at 400hp with intake chip and hybrids injectors.
1995 f250 2wd PSD, auto, DIY intake, DIY exhaust, PHP tuned 40hp tune , Hybrids injectors 238cc..... 13.618 in the 1/4 at 6000lbs.
1995 GMC 3500HD dump truck 6.5 turbo(lol) DIY intake and exhaust.
2008 GMC 2500 hd stock for now.EFI LIVE installed!!!!!
easy money is offline
post #7 of 12 (permalink) Old 03-09-2010, 11:28 PM
TDG Mafia Member #56
Dieselwrencher's Avatar
Originally Posted by Zaairman View Post
About $6000
It doesn't take $6000 to get to 400hp on them. He really doesn't even need the upgraded HPOP for 400hp either. Yes it'll help but it isn't needed. I made 455hp on my 97 with hypermax injectors, a custom banks ottomind chip, banks exhaust housing, an intake, and 4" exhaust, back in 2000. There are a lot more aftermarket parts and suppliers for the 7.3's now and more tuning options, so it shouldn't be real hard to get done.
Putco light bar
Dieselwrencher is offline
post #8 of 12 (permalink) Old 03-09-2010, 11:32 PM
Mod Friendly Title
Zaairman's Avatar
It doesn't take that much to get there, but it'll take that much to get that power to the ground...
Zach
SLAPS Member #153
Donut Video
Zaairman is offline
post #9 of 12 (permalink) Old 03-10-2010, 12:12 AM
heck its funner to make the power and then figure out how to hold everything els together later
but yes if you have an auto you had just as well figure on buying a transmission, if you have a 5 speed you can probably get by farly cheep with just a little clutch upgrade
Ross
Tow Rig
post #10 of 12 (permalink) Old 03-10-2010, 01:52 AM
My E40D was my worst problem.................. I went through 7 of them and a ZF 5 speed. I had different trans shops building parts or finding them as I broke them. I know the brunt of my money went into it, but I was sled pulling with it a lot too. Back then I beta tested for precision except it was a pay to test deal. Yeah it sucked. But it sure was fun putting a whooping on dodges and chevy's.
Putco light bar
GM says more than 400HP Jeremiah Duramax 2011+ (LML) 17 03-09-2010 06:23 PM
400hp 6.5L diesel ! ? ? ? M123KT-450 6.5L Diesel Engine 61 10-06-2009 09:41 PM
Broke 400hp... FINALLY!!! WNYPA Dyno Board 17 02-03-2008 02:17 AM
Cheapest way for 400hp. Psd715 1994-2003 7.3L Power Stroke 15 12-11-2007 06:19 PM
400hp imported_Smokem 5.9L Cummins 12 Valve (1994-1998.5) 14 01-19-2007 04:08 PM
