rear axel splitter? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tgf, this thread has received 16 replies and been viewed 3135 times.
post #1 of 17 (permalink) Old 03-13-2010, 02:30 AM Thread Starter
tgf
tgf's Avatar
rear axel splitter?
Curious to see if anyone has put a two speed rear end under a powerstroke. Saw a cummins with one the other day, just wasn't sure if its worth the modifications.
2002 F-350 psd. 6-speed. Deweze bail bed. Muffler delete, DIY Intake. 40 hp chip
tgf is offline
post #2 of 17 (permalink) Old 03-13-2010, 03:44 AM
pontiacross's Avatar
aussiedave has a gear vendors in his truck, its a little differant but he same idea
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 17 (permalink) Old 03-13-2010, 04:04 AM Thread Starter
tgf
tgf's Avatar
how does he like it?
tgf is offline
post #4 of 17 (permalink) Old 03-13-2010, 05:38 AM
I think he gets along good with it but not real sure, hopefully he'll chime in.
Ross
Tow Rig
post #5 of 17 (permalink) Old 03-13-2010, 07:06 PM
balz out's Avatar
what exactly would you gain from this? more bottom end power?
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #6 of 17 (permalink) Old 03-13-2010, 07:53 PM Thread Starter
tgf
tgf's Avatar
you can run at higher speeds at lower rpm without changing your gear ratio and better fuel economy
tgf is offline
post #7 of 17 (permalink) Old 03-13-2010, 07:56 PM
Mutley's Avatar
Mutley is offline
post #8 of 17 (permalink) Old 03-13-2010, 08:31 PM Thread Starter
tgf
tgf's Avatar
that seems to be the general consensus, and may be what i end up doin, but i've seen and heard guys pullin the axels out of old 2 ton trucks and makin it work. I'd just like to run at lower rpms and not be have to pull in od on big roads
tgf is offline
post #9 of 17 (permalink) Old 03-13-2010, 10:52 PM
balz out's Avatar
that being for the 5 speed how is it going to work in your 6 speed?
balz out is offline
post #10 of 17 (permalink) Old 03-14-2010, 03:57 AM Thread Starter
tgf
tgf's Avatar
they have them for 6-speeds too
tgf is offline
The worlds first $400,000 log splitter. Chobeeman The Parking Lot 8 12-24-2009 05:35 PM
Aftermarket overdrive/gear splitter questions Lonesome7.3 The Parking Lot 10 05-26-2009 03:30 PM
Gear Splitter for NV4500 Jawbone 5.9L Cummins 12 Valve (1994-1998.5) 17 03-20-2009 05:11 PM
axel bearings jay couch General Ford Truck and Excursion 0 09-17-2007 02:21 AM
AAM Axel Rich 5.9L Cummins (2003-2007.5) 6 10-03-2005 09:40 PM
