truck not firing or running - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Bruno2, this thread has received 16 replies and been viewed 6007 times.
post #1 of 17 (permalink) Old 03-17-2010, 03:39 AM Thread Starter
Bruno2's Avatar
I just got my truck back on the road and it was running better than ever . I took it for a test drive to see if the oil leak is fixed . I had driven the truck all day (50 miles) and it was reliable . When I did the test drive it thew the cel and died . The truck started and ran for about ten feet and then died and wouldnt start . I let it sit for a minute and it started and died immediately and then wouldnt start for several minutes and then did and died immediately after .
I changed the cps and nothing different , I changed the IDM and replaced it with one out of another truck , but , it was different and it didnt change the operation either . I had this problem a month ago and there was a code stored , but , my AE wouldnt recognize so I dont know what it was . I cleared the code and the truck went back to running right . This time there is no code stored and the cel light isnt on past the initial key turning .
7.3 psd ,Z-F5 , ARP headstuds , ARP main studs , D-66 dominator Turbo ,EBPV delete pedestal , MBRP 4" straight pipe , Rosewood stg II's , Tony's tunes 6 pos, K&N gen II intake ,comp 910 springs , Hurst line lock . Ford IC, Banks piping kit .
Alpine deck
Rockford Fosgate subs
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
HD leaf springs ,Over sized drive shafts , heavy duty precision u-joints all the way around
B.O.M.B. squad member #39
Singles Club member #251
Walnutter #8
Bruno2 is offline
post #2 of 17 (permalink) Old 03-17-2010, 03:59 AM
pontiacross's Avatar
dose the wate to start light come on?
I believe idms are interchangeable between all the years so no worries there.
oil pressure coming up?
fuel in the filter?
Ross
Tow Rig
Becker Brothers Enterprises
pontiacross is offline
post #3 of 17 (permalink) Old 03-17-2010, 04:00 AM
Big Stroker PSD's Avatar
maybe it is the cps this time ?
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #4 of 17 (permalink) Old 03-17-2010, 04:19 AM Thread Starter
Bruno2's Avatar
just changed the cps . there is fuel . yes I get the wts.
I am wondering about a bad uvch short or bad pin throwing the idm on limp.
Alpine deck
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
Walnutter #8
Bruno2 is offline
post #5 of 17 (permalink) Old 03-17-2010, 04:23 AM
usually if they do that it only kills the bank with the short, so it will hit on 4 cylinders.
how about oil pressure?
can you hear the injectors clicking while you crank it?
Ross
Tow Rig
post #6 of 17 (permalink) Old 03-17-2010, 05:03 AM Thread Starter
Bruno2's Avatar
I dont know about oil psi . i ill check to see if I can hear the inj clicking
Alpine deck
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
Walnutter #8
Bruno2 is offline
post #7 of 17 (permalink) Old 03-19-2010, 08:37 PM Thread Starter
Bruno2's Avatar
What do I do if the plugs going to the vc on the engine harness are bad? I there anything proper besides replacing the engine harness?
Alpine deck
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
Walnutter #8
Bruno2 is offline
post #8 of 17 (permalink) Old 03-19-2010, 08:39 PM
I would just replace them , dont think they cost much .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
post #9 of 17 (permalink) Old 03-20-2010, 04:54 AM Thread Starter
Bruno2's Avatar
OK the truck was running great , but , I havent been able to find the root of the problem . So I drove it over to buddies house to change the plug ends that had broken retainer clips and look for shorts in it . I found some bare wires at the end of the plug under the intake and thought this has got to be it . So I pushed the pins out and put them in the new ends . I made sure everything(all the wires) was in the same order. I made sure the pins were in securely . I coated everything with di lectric grease and re installed . The truck wont start at all now . The motor spins and spins no smoke no nothing. I ran some onboard diagnostics with my AE . I got a p1663 and a p0475 . I did a buzz test and no buzz . I got a p1668 code saying there was no connection to the pcm/idm. I did a live data meter while cranking and the icp spiked to 3300-3400psi and then dropped off like the ipr is working . So what the F now?
Alpine deck
Rockfod Fosgate amp
4 Pioneer 5x7
Clarion amp
Walnutter #8
Bruno2 is offline
post #10 of 17 (permalink) Old 03-20-2010, 05:07 AM
SmokeCloud's Avatar
Sounds like a bad UVC. pretty common in 7.3L
Real Trucks Burn Diesel!
SmokeCloud is offline
Truck running Hot?? woody_1 1994-2003 7.3L Power Stroke 10 08-01-2009 05:44 PM
Truck is not running right please help!!!!!!!!!! 2tonePSD 1994-2003 7.3L Power Stroke 0 10-21-2007 05:48 PM
Truck still is not running right, HELP!!!! 6point6 2003-2007 6.0L Power Stroke 13 03-15-2006 12:43 AM
I have a Running Truck Again!!!! LokiWolf 2003-2007 6.0L Power Stroke 7 02-05-2006 07:45 PM
Hot running truck sexytrkr 7.3L and 6.9 IDI (Pre 1994) 6 07-22-2005 07:53 PM
