side pipes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanss22, this thread has received 19 replies and been viewed 14380 times.
post #1 of 20 (permalink) Old 03-17-2010, 11:42 PM Thread Starter
side pipes
anyone ever tried to run a side pipe or duel side pipes on there 7.3 just for something different??
ryanss22 is offline
post #2 of 20 (permalink) Old 03-19-2010, 01:22 AM
balz out's Avatar
when i baught my truck it had a 4inch catback but over the axle was rotted so i cut and welded it made my own side pipe... big mistake. made my rear rim black and in the cab was alot louder... better off buying a turbo back performance exhaust
2000 f350 7.3 ext cab 6speed- 4inch dp, 5inch straight pipe, ts 6 pos chip. stock 140 100 75 50 high idle, zoodad, fpr shimmed, 6637 intake, 5inch lift, foil delete, beans idm, stage one injectors....r.i.p was fun when it lasted
94 mack rd e7350 mack 12speed roll bed
balz out is offline
post #3 of 20 (permalink) Old 03-19-2010, 05:11 PM
As a matter of fact i just did that yesterday
2001 F250, 7.3, Lariat, Crew Cab, Straight Pipe, 4X4... (140,000m)
redbaronmx319 is offline
post #4 of 20 (permalink) Old 03-20-2010, 12:01 PM Thread Starter
Could you post some pics please of how u routed it?
ryanss22 is offline
post #5 of 20 (permalink) Old 03-20-2010, 05:45 PM
Ya ill try and get some pics here in a little bit, all i did was kept the stock, cut right in middle right about between the two doors then put four inch to 90 degree bend up through bed to single stack... Had that for about 3 months and decided i didnt like it so i turned the bend sideways and put a 5 inch tip on.
post #6 of 20 (permalink) Old 03-23-2010, 01:36 AM
i have it unbolted where the muffler was and welded on a 45 degree, and put 3.5" straight right to the back tire....its true your tire does turn black but o well. very loud
2000 F250 XL 2wd
6637 DIY Intake- Ordered
AIH Delete- Ordered
Soon to have:
Some type of custom exhaust
Foil Delete
Isspro EGT, Boost Gauges
6 Pos TW Chip
pwrstk949 is offline
post #7 of 20 (permalink) Old 03-23-2010, 03:40 AM
4cstr's Avatar
Images: 35
Are you talking about running a big pipe under the door and exiting just rear of the cab like the old hot rods? If so, I saw a truck many years ago that somebody had done that to. For me..looked odd..I didn't like the look. If I remember who did it I will try to see if they still have a picture of it.
~Dave~
4cstr is offline
post #8 of 20 (permalink) Old 03-24-2010, 12:04 AM
Dec. Truck Of the Month!!
I have run mine out the side before the rear tire for years now. As for the black rims. Its not to bad. I get almost the same back on the fronts from the brakes. 4cstr, those Lariat rims I sold you were not all black were they....
From DieselPower Mag....
http://www.dieselpowermag.com/featur.../photo_12.html
I did not bend any pipes. Went to a local Auto parts store.
Not many carry 4 plus inch pipe so call around. I Bought a
10 foot stick of 4" pipe. Way to much, but smallest I could
buy from them. Bought a 4" down pipe and from there bolted
on a straight pipe about 3 feet long. The down pipe is
flanged to fit the pipe. At the end of the straight pipe I
used a coupler/flange to connect the next piece. A 60-degree
turn that has a flange on one end. With the flange at the
end of my project I could now finish it off with a 18"
piece of pipe out the side before the rear tire. It is all
adjustable depending on how you turn the pipes for endless
exit points. After I set my exit, I removed the last piece
and cut it to match the curve of the truck (slash
cut) everything was clamped with (6) SS band clamps. You will
need at least one hanging point. I have two.
I later added N-Fab bars that go from fender opening to
fender opening, so I had to exit below the bars. I added a
45 degree to the 60 degree and with that combo I could move
the pipes to exit up, down, side ways....countless ways,
very cool.
I have had it out the side like this for about 85,000 miles.
Windows up=sounds almost stock. Windows down=BAD ***
sound!!
I was at a clients shop that races NASCAR Craftsman trucks
the other day and REALLY like the side exit they use. Out
the truck bed body just in front of the rear tire. Might
give that a try because of the bars I added.
$125 Down Pipe
$50 10'of 4" pipe
$30 (6)SS band clamps
$25 60 degree turn
$12 flange adapter
$242 total
Could be less if you only count what you use out of the 10'
piece(4.5') for a total of $214.00. I think you could find
the 60/45/90 degree turn and flange adapter cheaper on line
too!
Hope this helps
Louie
2002 Super Duty CC Lariat 4x4, 7.3 PSD, ZF 6 speed w/LUK clutch & South Bend Kevlar PB, DP Tuner-AEB3,40,60,80,120,140, 1.15 A/R Van Turbo W/ATS housing and WW, Non-EBV Turbo Pedestal, CCV Relocated, 4" custom mid side exit straight pipe, Tymar intake, IH T 444E BADGES, 06 Grill, Ranch hand bumpers, N-Fab side bars, AIC, EX Console w/Wood & Rear Radio Controls, 3.73 LS, Husky Liners, Wet Okole seat covers, 2006 TT mirrors, Mastercraft 35" MUD tires on Helo Maxx 16X10 Black rims, Superlift 5" LIFT, Triple A-pillar Gauges, ARE Z Cap with 4'x5'x6" Con Ferr Roof Rack, 35" spare roof top mounted, Rhino Lined, GPS, CB, (320 RWHP and 700 RWTQ)....old #'s before Turbo and DP Tuner) Just added-OZ (Australian) amber turn signal taillights
TDG.com Truck of the Month
My Truck Site
FOKISD Charter Member
Bella PSD is offline
post #9 of 20 (permalink) Old 03-24-2010, 12:29 AM
DppPower's Avatar
My ex-stepdad has a buddy in Iowa that put true side pipes on his 99 right after he bought it new. They ran all the way along the bottom of the doors and turned out right at the back of the cab.
It really looked good but I am not sure if he even has it that way anymore as I have not seen him in years.
2008 F350 6.4L Crew Cab Short Bed - Few basic mods.
1999 F250 Reg. Cab - Twin Parallel Turbo Pulling Truck
"A woman who demands further gun control is like a chicken who roots for Colonel Sanders"
“Nobody can go back and start a new beginning, but anyone can start today and make a new ending.”
“For whosoever shall call upon the name of the Lord shall be saved” Romans 10:12-13
DppPower is offline
post #10 of 20 (permalink) Old 03-24-2010, 02:11 AM
4cstr's Avatar
Images: 35
Bella...no the rims weren't black.
To the OP...I think there is some confusion. Are you talking about an exhaust that runs under the truck and then exits in front of the rears...or true side pipes that run down the outside of the vehicle. Something similar to the picture below.
~Dave~
4cstr is offline
routing MAP to the hot side... AND cold side? Sleeperstroke 1994-2003 7.3L Power Stroke 2 06-20-2009 01:24 AM
Side Pipes Wild Wills 5.9L Cummins (2003-2007.5) 11 06-15-2007 08:25 AM
side pipes? outlawcrewcab 1994-2003 7.3L Power Stroke 9 04-16-2007 10:17 PM
Stacks or Side Pipes crzycowboy The Parking Lot 16 01-03-2006 10:11 PM
Side Pipes MotorCityDiesel 2003-2007 6.0L Power Stroke 10 10-22-2005 05:44 AM
