Yankin da Cat - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mutley, this thread has received 3 replies and been viewed 869 times.
post #1 of 4 (permalink) Old 03-26-2010, 10:20 PM Thread Starter
Mutley's Avatar
Yankin da Cat
When you fellas get rollin on rippin out the cat and running straight pipe, has anyone addressed the e-test issue? Up here in Ontario they e-test the diesels. My truck's still stock and I'm looking at the DIY intake and the downpipe treatment. Thanks in advance for your wisdom.
Mutley is offline
post #2 of 4 (permalink) Old 03-26-2010, 10:47 PM
bushpilot's Avatar
if you buy an MBRP cat delete/test pipe you can bolt the cat in & out in about
15min...if you DIY this an weld it you could be in for some trouble everytime
you get inspected !
the MBRP test pipe uses one clamp and two bolts, doesnt require alteration
to the factory exhaust & makes the switch-o-change-o EASY !
the test pipe is about 50 bucks !
Don R.
Truck Audio,
bushpilot is offline
post #3 of 4 (permalink) Old 03-27-2010, 03:20 PM
Big Stroker PSD's Avatar
you get inspected !
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
post #4 of 4 (permalink) Old 03-28-2010, 04:18 PM
Send a message via AIM to flatbed
got a 95 7.3 f 350 .......anybody ever heard of a "y" cut out on the down pipe , either manual or automatic (from a cab switch). I would run a second pipe off the "y" back under the bed.
my question arises from DOT inspections hauling HAZ MAT ( EXPOSIVES) they are gonna want to se the cat and muffler and hope they arent going to bust me for altering when giving the excuse the "Y' is there for engine testing purposes.... Thanks
flatbed is offline
My old 2000 yankin' the sled..... diesel dan 1994-2003 7.3L Power Stroke 1 05-13-2006 03:05 AM
