99 F350 headlight staying on all the time - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jack#8, this thread has received 3 replies and been viewed 2417 times.
post #1 of 4 (permalink) Old 03-27-2010, 01:33 AM Thread Starter
jack#8's Avatar
Ive got a 99 F350 with the headlights staying on all the time. I have replaced the headlight switch and the turn signal (mf) switch. Anybody have any ideas on what to check next? thanks
jack#8 is offline
post #2 of 4 (permalink) Old 03-27-2010, 03:22 PM
Big Stroker PSD's Avatar
Sounds like you might have a wiring problem . I would trace all the wires back from the lights and check for bad spots in the wires .
Dusty
Ridin Dirty #59
B.O.M.B Squad # 78
Big Stroker PSD is offline
The Following User Says Thank You to Big Stroker PSD For this addition to TDG:
jack#8 (03-27-2010)
post #3 of 4 (permalink) Old 03-27-2010, 03:30 PM Thread Starter
jack#8's Avatar
Thanks Trying to make sure there is nothing else other than the wiring
jack#8 is offline
post #4 of 4 (permalink) Old 03-29-2010, 11:52 PM Thread Starter
jack#8's Avatar
Found my problem
jack#8 is offline
4X4 not staying engaged littlebigrig6.0 General Ford Truck and Excursion 8 02-14-2010 01:41 AM
Cooling Fan staying on/engaged all the time International350 2003-2007 6.0L Power Stroke 10 11-12-2009 02:50 AM
96 f350 headlight problem 96 stroker 1994-2003 7.3L Power Stroke 2 11-11-2007 01:21 PM
Radio Staying on imported_bsutton2000 1994-2003 7.3L Power Stroke 4 10-03-2007 02:19 AM
Truth or myth? Could one buy a F350 stock with a Cat at one time? Lonesome7.3 General Ford Truck and Excursion 11 11-17-2006 10:25 AM
