trouble starting - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Goodolboy, this thread has received 2 replies and been viewed 1097 times.
post #1 of 3 (permalink) Old 03-28-2010, 05:24 PM Thread Starter
Ford F-250 Stroker
Goodolboy's Avatar
trouble starting
I have a 2000 7.3 and im having trouble getting it started. if i drive it every day usually no problems but if i skip a day then it will crank and crank and crank and wont fire up. if i hook up a pair of jumper cables up and it'll start. anybody know whats going on?
Goodolboy is offline
post #2 of 3 (permalink) Old 03-29-2010, 12:58 AM
bpogue's Avatar
Sounds like it could be a bad battery. It takes 2 strong batteries to start them, in most cases. I would have both load tested individually. Even though it seems to be cranking over fast enough to start, it might not be quite enough.
1996 Int 4700, 175hp DT466, 5 speed, 2x rear end, service body
2001 F350 SRW flatbed, 4x4, crew cab
1978 International F2275 Dump Truck
1996 NH LX665, steel tracks on foam filled tires
2005 Tackeuchi TB145
2003 Takeuchi TL150
Case 850B Highlight, 4 way bucket
bpogue is offline
post #3 of 3 (permalink) Old 03-29-2010, 12:59 AM
I agree. Sounds like weak batteries that won't hold a charge for more than a day.
Pocket is offline
intermittent starting trouble wildshipe 7.3L and 6.9 IDI (Pre 1994) 2 04-09-2008 04:11 AM
Trouble Starting fordsthebest 1994-2003 7.3L Power Stroke 3 03-03-2008 03:55 AM
starting trouble bullrider 17 6.5L Diesel Engine 5 12-10-2007 05:29 PM
Starting trouble STROKETHIS7.3 1994-2003 7.3L Power Stroke 2 11-08-2006 02:15 PM
