help with hpop install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanss22, this thread has received 12 replies and been viewed 3385 times.
post #1 of 13 (permalink) Old 03-29-2010, 01:38 PM Thread Starter
Ok so I just intstalled an adrenaline hpop, diy inj, and a reg. Ret fuel system. On my 96. I have a problem with keeping oil pressure up after the truck is shut off and sits for more then 5 min. If I try to star it the oil pressure gauge reads on the dash reads nothing untill I crank wit for about 5-6 revolutions then it picks up oil pressure and fires right up. What gives?? The instructions with the adrenaline are kinds of vauge. Was there anything else I needed to put in the adrenline from the stock hpop besides the fittings? I left out the spring and that stufff from the stocker as per the the instructions. Any ideas??
ryanss22 is offline
post #2 of 13 (permalink) Old 03-29-2010, 05:13 PM
maybe they sent you the wrong pump. i think you may need a pump with a internal anti drain back valve. someone could tell you better then me just my guess.
1995nicholas is offline
post #3 of 13 (permalink) Old 03-31-2010, 03:26 PM
Cratos's Avatar
you still have air in thre system give it a day of driving to get it out. if you still have the problem give bob a call.
2012 f-240 lbsc 4x4
Cratos is offline
post #4 of 13 (permalink) Old 03-31-2010, 11:10 PM
What Cratos said.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #5 of 13 (permalink) Old 04-01-2010, 09:01 PM
excellant timing. I'm finishing my Adrenaline pump install this evening.
rf1101 is offline
post #6 of 13 (permalink) Old 04-02-2010, 07:06 AM Thread Starter
Rf1101 did you have any problems with the install? Any of the same issues that I meationed??
ryanss22 is offline
post #7 of 13 (permalink) Old 04-03-2010, 01:49 PM
No problems with the hpop install, but I havent started my truck yet, because I am replacing the core support due to rust, and my fuel filter housing had two dimples in the bottom, that became holes when I probed them with a pick tool. Glad I caught that now. I hope to fire mine up by sunday evening. I'll let you know.
rf1101 is offline
post #8 of 13 (permalink) Old 04-04-2010, 07:04 PM
Thumbs up JUST IN TIME!!
Looking at buying the adrenaline pump. How would you rate it? I'm also going with stage 2 diy'ers. Know if anyone has done a write-up on removal and install? Let me know what you find out on the pressure loss problem
PennyPinchingPowerStroke is offline
post #9 of 13 (permalink) Old 04-04-2010, 10:28 PM
Cratos's Avatar
Oil loss ??what are you talking about?
2012 f-240 lbsc 4x4
Cratos is offline
post #10 of 13 (permalink) Old 04-07-2010, 02:29 AM
Yes the oil pressure loss. Just ordered mine
HPOP 8yourv8 Supporting Vendors Forum 3 10-09-2009 05:03 PM
17* Hpop stroker_baldy Whats Been Sold 8 01-04-2008 01:10 AM
HPOP install help stroker_baldy 1994-2003 7.3L Power Stroke 3 10-15-2007 11:38 PM
Sd Hpop Install On Obs? strokedout_07 1994-2003 7.3L Power Stroke 13 07-26-2007 03:55 AM
HPOP install.....OBS BigRed97 1994-2003 7.3L Power Stroke 1 11-10-2006 02:42 PM
