7.3 Won't Start - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Seafordguy, this thread has received 18 replies and been viewed 2652 times.
post #1 of 19 (permalink) Old 03-29-2010, 07:51 PM Thread Starter
7.3 Won't Start
Alright - after replacing the ICP about 1000 miles ago, the truck ran well. It began hesitating a little over the weekend and grew TERRIBLE during Sunday and today....
I decided to replace the Fuel Filter as a precaution, and did about 10 minutes ago - fired it up, let it run about 5 minutes, backed out of the driveway, it cut off on me, and now it won't restart.
Any ideas?
Oil Level is not a problem, Fuel Level is not a problem - I did the CPS recall, but I am going to go out right now and look. I am worried that sounds like the culprit. EDIT - just looked, and I have the Gray one....
Thoughts?
EDIT again - I show nothing on the Tach when I crank it over, and I believe that signal comes from the CMP (CPS) doesn't it?
Seafordguy is offline
post #2 of 19 (permalink) Old 03-29-2010, 08:19 PM
plainredtruck's Avatar
Images: 11
Most likely is the CPS.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 19 (permalink) Old 03-29-2010, 09:12 PM Thread Starter
Replaced CPS, started up, drove 200 feet, cut off??
post #4 of 19 (permalink) Old 03-29-2010, 10:44 PM Thread Starter
Can hear the fuel pump on the frame rail running.
When I took the cap off the fuel bowl and cranked it it filled the bowl in about 10-12 seconds. Is that sufficient fuel pressure?
NO smoke at all.....
post #5 of 19 (permalink) Old 03-29-2010, 10:59 PM
SmokeCloud's Avatar
Do a fuel pressure test. Have you done a buzz test on the injectors.
Real Trucks Burn Diesel!
SmokeCloud is offline
post #6 of 19 (permalink) Old 03-29-2010, 11:08 PM Thread Starter
No - can you walk me through that?
I'll search in the mean time....
post #7 of 19 (permalink) Old 03-30-2010, 01:14 AM Thread Starter
Started up, drove about 200 feet, crapped out on me, wouldn't restart??
When I took the cap off the fuel bowl and cranked it it filled the bowl in about 10-12 seconds. Is that sufficient fuel pressure? It will build pressure in the bowl such that when you let the drain petcock out it comes squirting out.
It just sat for a while and when i just cranked it, it started and ran for the briefest of seconds, and now won't restart at all?
No codes.
It is almost as if it isn't getting any fuel at all?
post #8 of 19 (permalink) Old 03-30-2010, 02:53 AM
SmokeCloud's Avatar
Which one do you want a walk through on.
Have you checked your voltage on the IDM as well?
post #9 of 19 (permalink) Old 03-30-2010, 02:56 AM
Mine did the same thing couple of weeks ago. Turned out to be feul pump. Funny thing i could hear it running & felt the virbration & it was still bad.
dshackle3 is offline
post #10 of 19 (permalink) Old 03-30-2010, 02:58 AM
SmokeCloud's Avatar
I want him to test the pressure first, even though you had a simular symptoms, doesn't neccesarily mean that's the problem.
Strange Cold start/no start/start changexlt 2003-2007 6.0L Power Stroke 7 12-23-2008 10:00 PM
Rough start and white smoke at cold start? bassn_07 2003-2007 6.0L Power Stroke 11 03-02-2008 11:57 PM
04-17-13 Hard Start Or No Start - Gpcm Connector Service Kit Available - 6.0l Engine Squatch Ford Oasis requests 0 03-23-2007 12:55 PM
CRANK NO START, HARD START, RUNS ROUGH AT IDLE - 6.0L 2005 F, E-Series,and Excursion PSDPlayer 2003-2007 6.0L Power Stroke 0 10-08-2005 08:32 AM
