got a problem and need help!! got a miss!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by powersmoke18, this thread has received 7 replies and been viewed 1227 times.
post #1 of 8 (permalink) Old 04-08-2010, 02:32 AM Thread Starter
Send a message via AIM to powersmoke18
well i had a customer come to me with a no start 7.3. he said he did injectors because they failed. well after a little check over we found the relief valve on the filter housing had an oring jammed in it. so we replaced it and got her up and running. today i got a call that the engine wouldn't even pull the truck up over the hill by his house and it stalled out. so i went down to take a look and it fired right up when i got there and ran great. it idles fine and it has full rpm but when you drive it down the road it starts missing and eventually misses so bad it shuts off. any ideas?? so far it has new injectors, new pressure relief valve, new fuel filters.
thanks guys!!!
powersmoke18 is offline
post #2 of 8 (permalink) Old 04-08-2010, 02:39 AM
plainredtruck's Avatar
Images: 11
what year is it?
Check the under valve cover wiring harness (UVCH).
Did you ask him where he got the new injectors? Has he had them tested since they were installed?
Any other info you can provide?
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #3 of 8 (permalink) Old 04-08-2010, 03:12 AM Thread Starter
the international dealer he said. they were all new tho. not rebuilt. i checked over the harnesses in the heads they look good. its a 99.5. wish he would have brought it to me first. we are doing the work for free because he kinda screwed himself. plus he had 2 strokes in the past 9 months so hes had some bad luck.
post #4 of 8 (permalink) Old 04-08-2010, 01:29 PM Thread Starter
well hes been running biofuel to come to find out. collapsed line maybe??
post #5 of 8 (permalink) Old 04-08-2010, 01:33 PM
Images: 11
Change the filters again.
He could easily have a clogged filter running biodiesel.
Might want to check the fuel pressure as well.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #6 of 8 (permalink) Old 04-08-2010, 01:59 PM Thread Starter
ya ill try the filter but i just think theres more to it.
post #7 of 8 (permalink) Old 04-08-2010, 05:29 PM
7.3 addict
i run 100% bio on my 99 and have never had a prob other than filtes getting dirty. doubt about a line collapsing
1) 99 f-350 srw 7.3 6pos. bully dog, afe intake, mrbp 4" exhaust,250,000 miles and still rollin.
2) 2000 excursion 7.3 afe intake, mrbp 4" exhaust. chip coming
3) NEW TO ME2000 cc drw 7.3 let the mods begin
4) FOR SALE 87 f250 6.9 9' utility body.
5) SOLD 91 f150 good truck just well used.Gonna miss the old girl allways started even after sitting for 6 months.
I think i'm trailer poor ) 22' w\18' tilt car hauler, 18' flat bed, 2 horse D&D, 12' utility, 19' "v" nose, and 37' 5er
"quote from tank"
"I use baby wipes.....
Because if you think that a wadded up piece of paper is actually getting the chit off of your butt.....then I have to ask a question....
.....if you wiped a turd on your arm....would you just use a paper towel to get the turd off?.....or would you wash your arm?...
...let that thought roll around in your head for a moment...
" thank you tank for that insightful thought
#46 AMERICAN (blood) club
#241 singles club
# ? Dually club
# ? Excursion club
jestersv is offline
post #8 of 8 (permalink) Old 04-10-2010, 06:48 AM Thread Starter
well we put some compressed air thru the lines and bam!! truck runs great!! dropped the tank hoping to find something but no luck. so who knows. transfer pump holds a steady 65psi pulling big hills. thanks for the help guys!!!
Hit or miss? bmoeller 5.9L Cummins (1998.5-2002) 2 03-25-2009 02:22 AM
mystery problem/miss? Super10lbz 5.9L Cummins (2003-2007.5) 3 12-05-2007 11:56 PM
did I miss something? rockpsd The Parking Lot 9 04-03-2006 12:38 AM
