Need some advice on trans - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by sidssm, this thread has received 9 replies and been viewed 1534 times.
post #1 of 10 (permalink) Old 04-08-2010, 10:37 PM Thread Starter
sidssm's Avatar
Hello all. My early 99 7.3 auto has started making a rattle at idle after warm up. The sound seems to be coming from the torque converter. I removed the dust sheild and all the bolts are tight and I couldnt see any cracks in the flex. If I idle the truck up the noise goes away and it lessens when I put it in gear. The trans shifts great and I havnt had any issues with it. What should I do? Thanks Seth
99 F350 4X4 CC DRW LB 7.3 AUTO STRAIGHT PIPE, 4.10s,Tymar, Gauges, 02 turbo, tugger 2, racerx 6xtc,05 front end, dp tuner, 120 idm.
08 F250 PROJECT THEFT RECOVERY.
sidssm is offline
post #2 of 10 (permalink) Old 04-09-2010, 12:07 AM
trackspeeder's Avatar
Replace the converter.
01 F250 4X4, 7.3.
90 F350 4X4, 7.3
85 F250 4X2 6.9
08 Arctic Cat 700 4X4, Diesel
Easy button for photos
trackspeeder is offline
post #3 of 10 (permalink) Old 04-09-2010, 12:26 AM Thread Starter
sidssm's Avatar
Can I just replace the converter? Is there anything else that I need to do while the trans is out? thanks seth
sidssm is offline
post #4 of 10 (permalink) Old 04-09-2010, 12:48 AM
RussK's Avatar
If you catch it early enough just the converter, if you wait to long you may have to do the Trans as well. Pull the pan and see what’s in it first. If there is a lot of metal you may already gone too far.
2001/05ish f250 Lariat 4x4 automatic, airaid intake, custom paint, 4 tan bucketsí covered in dead cow skin, wood dash & trim,gauges,elc trans cooler,Custom door sill lights (light up ground when door opens) Lots and lots of sound deadening other than that pretty much stock
Mercedes e320 (wifeís)
Nissan Maxima (work driver)
Dodge Magnum (work driver)
Trx 250r (off road adrenalin pump)
FORD 3600 diesel tractor
Singles club #164
american club # 9
I want to die while asleep like my grandfather,
not screaming in terror like the passengers in his car.
Russell
my truck from the begining
http://s391.photobucket.com/albums/o...um/my%20truck/
RussK is offline
post #5 of 10 (permalink) Old 04-09-2010, 01:59 AM
plainredtruck's Avatar
Images: 11
You could replace the valve body since you'll have it out and the fluid drained anyway.
If you have the tools, there are some pump mods you could do.
Contact our resident Ford transmission vendor, Racer X for his suggestions.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
My Photography addiction
Mafia # 27
plainredtruck is offline
post #6 of 10 (permalink) Old 04-09-2010, 02:31 AM
Erly 99 and late 99 trucks were known for this to happen. I think part is due to the fact that the TC is so loose and the other thing i heard was it was a defective design. My truck does it too and it only has 57K on her. When she locks up the noise goes away. It don't slip or chatter at all so when it starts to do that then I will replace mine.
cumminsdude2001 is offline
post #7 of 10 (permalink) Old 04-09-2010, 03:41 PM Thread Starter
sidssm's Avatar
Prt, I plan on getting my parts from racer x, he has guided me on some transmissions in the past but I was able to fix them without ordering parts. I dont know which tc to purchase.
sidssm is offline
post #8 of 10 (permalink) Old 04-09-2010, 05:48 PM
Images: 11
I've heard great things about the converter he specs.
I plan to have mine done by him (very soon, actually) since he's fairly close to me.
prt
'99 F250 X-cab 2wd
powered by DP-Tuner
Mafia # 27
post #9 of 10 (permalink) Old 04-09-2010, 09:59 PM
Check out his converters.
01 F250 4X4, 7.3.
90 F350 4X4, 7.3
85 F250 4X2 6.9
post #10 of 10 (permalink) Old 05-13-2010, 06:31 AM
hayjayhorses's Avatar
I put a Precision of New Hampton, Max low stall billet multi disk converter in my '00 F550 and i really like it. It cost about $525 shipped and I have had it in for 40k plus miles hauling hay (I weigh 40,000 # loaded) and horses and it is holding up fine. I have a friend who rebuilds all his trannys with Precision's converters and they hold up very well.
www.gopnh.com
They don't spend a ton $$$ sled pulling like ATS and others or run multi page adds in Diesel Power or other magazines. when you pay $1000 plus for a converter your most likely paying for full page adds in magazines and sled pulling trucks.
Jay Noone
413-222-8286
I got hay
Vote Ron Paul 2012
hayjayhorses is offline
Need some advice versitek 2008-2010 6.4L Engine Tuner Forum 8 02-02-2010 03:54 AM
advice? bigswede Medium and Heavy Duty 2 01-23-2010 06:46 AM
vendors advice and expert advice needed silverpeteok 5.9L Cummins (1998.5-2002) 11 01-25-2009 11:08 PM
some advice on gsk smokeisfun 5.9L Cummins 12 Valve (1994-1998.5) 2 04-14-2007 10:00 PM
Advice SeeYa General Gas Vehicle 17 02-06-2006 09:50 PM
