IPR Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Seafordguy, this thread has received 4 replies and been viewed 1231 times.
post #1 of 5 (permalink) Old 04-10-2010, 04:12 AM Thread Starter
IPR Question
When I pulled mine out to clean it the two o-rings were in good shape, but the plastic ring was snapped all the way in one place. Is it supposed to be like that?
Seafordguy is offline
post #2 of 5 (permalink) Old 04-10-2010, 04:15 AM Thread Starter
Picture Reference.
In the top two pictures at the bottom of this PDF I am talking about the black ring that is on the left, that sits beside the greenish O-ring....
post #3 of 5 (permalink) Old 04-10-2010, 04:25 AM
4cstr's Avatar
Images: 35
I am trying to remember the last time I had mine out. I believe it was split. When I get back home later this weekend I will go out to the shed and look at the spare IPR that I have to see if it also has a split.
~Dave~
4cstr is offline
post #4 of 5 (permalink) Old 04-10-2010, 04:32 AM Thread Starter
Yeah - I am not sure you could get it on otherwise, but I could be wrong. I am going to pull it back out in the morning.
My no start problem wasn't the IDM, and looking back on it it was odd that the truck started and ran with the little needle valve in oneway, but when I turned it the other way (the way shown in that picture) it didn't start, and now I am just wondering if that IPR is a culprit.
post #5 of 5 (permalink) Old 04-10-2010, 01:56 PM Thread Starter
Alright - ANOTHER question on the IPR.
Does the small needle go in the direction it is shown in the PDF picture or the other way?
Reason I ask is because the truck will positively NOT start if it is assembled as shown in the picture, but it fires right up if it is put together with the needle pointing the OTHER way.???
Turbo Question(Tech Question) Liftedpsd 2003-2007 6.0L Power Stroke 7 09-16-2007 04:35 PM
Boost question, maybe MAP sensor question 6_Myles 1994-2003 7.3L Power Stroke 5 10-28-2006 01:42 AM
Edge Juice Question Question Jaadc01 General Ford Truck and Excursion 6 05-23-2006 01:40 PM
