help!! high egt's after install - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by ryanss22, this thread has received 8 replies and been viewed 3571 times.
post #1 of 9 (permalink) Old 04-13-2010, 01:53 AM Thread Starter
ok so i just got done modding my truck (96 obs) and i did them all at once and heres the list:
intercooler installed
regulated return fuel system
adrenaline hpop
rosewood stage 2's
3" down pipe to single 5" stack
idm mod
gauge install.
ts chip
everything went well and the truck fires up and runs great
my problem is that when going down the road at about 60 on the stock setting i am seeing about 1000* on my gauge, if i bump it up to level 1 or 2 then they drop back down to around 700* but she bellows the smoke, (dnt want a ticket)
we noticed that my exhaust manifolds are leaking a bit would that be a cause of my extreme egts? any ideas?
I am wondering if the exhaust manifolds from a 99 or newer 7.3 would fit my obs? they look physically bigger so should flow more, also is there any way to modify the fire wall to exepct a 4" dp?? it was a PITA to get the 3" in but im trying to figure out ways to lower my egt's.
any help here guys??
ryanss22 is offline
post #2 of 9 (permalink) Old 04-14-2010, 05:35 AM
moose99psd's Avatar
the manifolds off a sd are diffrent uppipe routing so unless you want to convert over to a SD turbo set up thats out. uppipes and manifolds leaking could cause higher than expected egts
moose99psd is offline
post #3 of 9 (permalink) Old 04-15-2010, 03:57 AM
That is a lot of mods to do all at once. Might take a bit of retracing. I agree that leaky up-pipes could increase EGT. Are you running the stock turbo with those stage 2s and everything else? If so EGT could easily on the warm side.
97rattlebox is offline
post #4 of 9 (permalink) Old 04-15-2010, 07:22 AM
joebob3093's Avatar
Send a message via Yahoo to joebob3093
it might be in your tuning. are you running stock TS tuning? its very posible you have a boost leak. when we did my IC i had a couple boost leaks i needed to fix.
{95 F250 Powerstroke XLT} 5 spd, Wildman 6 pos. chip, custom IC, ADs, AFE stage 2 intake, 3" down pipe to custom 5in stack. EBPV break, shimed FPR, idm mod by mattymx, CCV mod, Leveling Kit, diprocol egt and boost guages.
joebob3093 is offline
post #5 of 9 (permalink) Old 04-15-2010, 10:55 AM Thread Starter
yes I am running stock ts tunes, I know I need to send it out for a reflash for my mods. and yes I still am running the stock turbo also.
ryanss22 is offline
post #6 of 9 (permalink) Old 04-15-2010, 11:02 AM Thread Starter
i forgot to mention that i am in the process of replacing my manifolds and will try that. the passenger side had a vissible crack in it and driver side had a pin hole would that be enough for the boost to leak out that much?
ryanss22 is offline
post #7 of 9 (permalink) Old 04-18-2010, 04:38 PM
van_350sd's Avatar
Are the Stage 2's 22, 24, 27 lpm?
Don't forget your dumping a lot of fuel in there, what pressure are you at?
Do you have a fuel pressure gauge inside the cab or just under the hood?
It's important to get your fuel pressure right and then check the timing.
Look at the timing on all levels, stock, 60, 80 or whatever you use.
2000 E350-Super Duty-ExplorerExt. Mobile LivingRoom-7.3LPSD-3:55LS-Dual AmsoilEaA Air Filters-AutoMeter Phantom Guages-Pyro(Pre)-Boost-Tranny+Hobbs Hour Meter-C2 Pyro(Post) WaterTemp - 4"SS MagnaFlow Wrapped w/ Thermo-Tec 2" Header Tape-SonnaxValve+Tricumulator Shift Springs-Mag-Hytec Tranny+Rear End Cover-1 UpFront Spring Option-Bilstein's-Centramatic's-35 Gallon MainTank+TraxII TransferFlow 27 Gallon Aft.Aux.Tank=62 Gallon Range-ACPM/AIC-DualBattery+Alt-450 FilterMAGx2-Fumoto-ALL Amsoil-Bob's 203*&Billet Housing-Alcoa Classics-Explorer Conversion Installed DynaMat Complete Interior - 4 Leather Captain Chairs/BackSeat/Bed-Hellwig Sway Front/Rear-48"Hi-Lift-C02PowerTank5#SnapOn1/2"ImpactMG725-H3RCleanAgentHalotron2.5#
van_350sd is offline
post #8 of 9 (permalink) Old 04-19-2010, 03:54 PM
S10
Built not bought...
With the list of nice mods u have already, a stock turbo and a 3" dp will prob still cause higher than stock EGTs. Even if u fixed any leaks u may have. Kind of a bottle neck in the exhaust now if u know what I mean. PM me and I can give u a guys number that can prob help u with a 4" DP mod. And give u some tips on what turbo would be better if u want.
S10 is offline
post #9 of 9 (permalink) Old 04-20-2010, 10:46 PM
Cratos's Avatar
st 2's and stock turbo =
2012 f-240 lbsc 4x4
Cratos is offline
High EGT's eby94 6.7L Cummins (2007.5-2011) 18 02-17-2009 01:48 AM
High EGT'S GOFASORGOBROK 2003-2007 6.0L Power Stroke 7 04-17-2008 10:39 PM
High EGT's? Superdutytd 2003-2007 6.0L Power Stroke 11 08-01-2007 04:07 AM
What would cause High EGT's ... DemonicF350 2003-2007 6.0L Power Stroke 6 11-30-2006 12:49 PM
High EGT's HillbillySD 2003-2007 6.0L Power Stroke 7 05-16-2006 06:09 PM
