oil pressure - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by lapwrstroke, this thread has received 10 replies and been viewed 2121 times.
post #1 of 11 (permalink) Old 04-18-2010, 12:31 AM Thread Starter
oil pressure
i have a 2000 f-250 and after warming up awhile my oil pressure goes crazy. at idle it drops to nothing and the light comes on but as soon as i get around 800 rpm or more it jumps to normal. i changed the oil pump on the bottom front of motor and that did not fix the problem. anybody have any ideas i am at my wits end
lapwrstroke is offline
post #2 of 11 (permalink) Old 04-18-2010, 08:34 PM
Is your oil viscosity down from fuel dilution? Is your oil filter plugged?
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. BDP modded IDM. Heim joint clutch linkage. Adrenaline HPOP. LUK SMFW. DIY Elec. Fuel. FS1282, FF5230 fuel filters.
sdan27 is offline
post #3 of 11 (permalink) Old 04-18-2010, 10:15 PM Thread Starter
just did an oil change and still no change. oil looked good. am thinking it may be a pick up tube. any suggestions on the best way to drop the oil pan or does the motor have to come out.
post #4 of 11 (permalink) Old 04-19-2010, 04:20 AM
Maybe your sensor is giving a bad reading. I mean, if you had such low oil pressure, the engine would stop running and there would be no oil to the injectors. Try a mechanical gauge and see what that says. If it were the pick-up tube, it doesn't seem like oil pressure would be any better revving the engine up. You can try to overfill your oil level to cover whatever crack might be in the pick-up to see if that does anything.
sdan27 is offline
post #5 of 11 (permalink) Old 04-19-2010, 05:42 AM
you probably need a sensor
the trick you by putting in a gauge but its actually a switch,either its at half or low.
stevemic is offline
post #6 of 11 (permalink) Old 04-19-2010, 08:31 PM
I asked him that in the 911 section. he did install a mech gauge and got 4 psi at idle so yes it is actually low, and it did make good pressure at higher rpms. i suggested having a look at the oil pressure relfe valve
2006 yamaha Vmax
2003 suzuki 1000 GSX-R
1993 F-250 460
Near GP alberta.
CC#58
budtoh3zo is offline
post #7 of 11 (permalink) Old 04-20-2010, 04:51 PM
SRW Cartell #27
Stacked6600's Avatar
where is the relfe valve located?
1999.5 F250 4x4 super cab 7.3L With edge attituede.
Converter lockup mod and EBPV exaust brake mod.
Air Hog cold air intake. Muffler delete, 35s on centerlines.
New F650 dash upgrade..
1995 F250 Single cab long bed 2wd.
2001 LB7 2500HD SOLD
AEM Brute Force intake, 5 1/2 stack exaust, Diablo Sport Predator Programmer. PPE boost valve, Autolite gauges. Built Allison (Alto steels, Red eagle clutches, Transgo shift kit, transgo lockup valve, and Personal Mods : ) edelbrock 1792 lift pump.
Singles Club Member #27
Stacked6600 is offline
post #8 of 11 (permalink) Old 04-21-2010, 01:43 AM
I think there is a regulating valve and a bypass valve in the filter header.
sdan27 is offline
post #9 of 11 (permalink) Old 04-22-2010, 03:08 AM
im not sure on the 7.3L but there has to be one somewere. on the 6.0L its in the front cover.
2006 yamaha Vmax
1993 F-250 460
Near GP alberta.
CC#58
post #10 of 11 (permalink) Old 05-26-2010, 01:40 AM Thread Starter
well i had my problem solved had to drop a new motor in the truck. the shop found the cam bearings in the oil pan.
How do I change the pressure of the tire pressure sensors? Klutch 2008-2010 6.4L Engine Tuner Forum 3 11-23-2009 03:09 AM
Fuel pressure & rail pressure gauges??? SS1156 5.9L Cummins (2003-2007.5) 9 07-23-2009 07:33 PM
Fuel pressure & overflow valve pressure Deeslfxr 5.9L Cummins (1998.5-2002) 4 01-10-2009 12:35 AM
Setting fuel pressure regulator w/out a fuel pressure gauge hhrecovery 2003-2007 6.0L Power Stroke 17 04-02-2007 03:25 PM
Any way to boost Low pressure oil pressure? CSIPSD 1994-2003 7.3L Power Stroke 6 10-10-2006 02:15 AM
